Old 01-28-2013, 08:21 AM   #29
2006 30' Classic
Milton , Florida
Current AS Owners
Originally Posted by macofpei View Post
I am the second or third owner of my 2003 Classic and, of course, our name isn't on the original owners card that was sent to JC ( if original owners cards are sent).
My question is-- since I am not the original owner, how would I get my name of a list of 2003 Classic owners who might have a recall issue on my unit that I could not possible have been notified, by mail?
Does this make sense?
I am a member of wbcci, #4782
Contact Randy McNeely : Randy McNeeley [mailto:rmcneeley@airstream.com] via email and provide him with proof of ownership and he will place you on the owners list. This will provide you with future recall notices.
In my case, I sent him a copy of my Florida vehicle title.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 01-28-2013, 08:29 AM   #30
2006 30' Classic
Milton , Florida
Recall Refund
Originally Posted by boondockdad View Post
Do I have any recourse on getting reimbursed for repairs already done?
I actually had a conversation with Parrott when this happened, almost two years ago. It was obviously a design flaw. I wanted to know what they were going to do to fix it, and he basically told me to pound sand.
Airstream is providing reimbursement to owners of units under the recall notice that can provide documentation of ownership of the TT and receipts for the costs of repairs. Contact Randy McNeeley [mailto:rmcneeley@airstream.com] at JC.
At least, this is what was done in my case.
F. A. Meloy
2006 30' Classic
Old 01-28-2013, 09:05 AM   #31
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
nickmeloy,
That seems darn resonable on their part. Too bad I did it my self, but that was my choice and since installed, I have had no issues with the revised line configuration that I came up with.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-28-2013, 12:02 PM   #32
Ottawa , ON
No, I never even thought about it until I saw this recall. I guess I will be writing a letter soon.
Good luck!
Old 02-08-2013, 04:36 PM   #33
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Friends: I had the brake recall work performed yesterday at Bill Thomas RV in St. Louis and it took the repairman most of the day! He had a very tough time with a fitting that would not seat. And he found a blocked line, which he fixed. I towed 300 miles today and really enjoyed the feel of the newly reworked brakes. This was wonderful service and great factory support. Thank you Bill Thomas and Airstream!
JBinKC is offline   Reply With Quote
Old 02-08-2013, 05:04 PM   #34
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 34
Andy, thanks for the valuable info! I just signed up on the NHTSA website for notices related to our 2011 Airstream. It was simple.
As far as I know, this is the oldest I've ever been.
Road Geezer is offline   Reply With Quote
Old 02-10-2013, 06:46 AM   #35
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
New hoses fitted last week after being airfreighted by JC.
JBinKC - possibly this was your problem.
The tech guy initially discarded the brass fiting that connected the old hose end to the caliper and tried to screw the new flex hose flare nut straight into the caliper (this would have resulted in a flare to flare connection and would have leaked). I had to point out to the tech guy that this brass fitting should be retained, which he did, and all hoses seated correctly.
John in the UK
WK57ABF is offline   Reply With Quote
Old 11-13-2017, 06:13 PM   #36
GCinSC2's Avatar
Folks,
Suggestion.
Look under your trailer and inspect the routing of the new hoses. Look on the frame, do you see evidence of the hose rubbing on the frame? Then look at the hose for a flat spot from rubbing. No rub marks? That's what you want to see.
I just saw this on another trailer that had the recalled hoses. It can most likely be re-routed with a bit of sweat equity, but be careful.
Gary
S/OS #001
Old 11-13-2017, 08:19 PM   #37
dznf0g's Avatar
Oswego , Illinois
Originally Posted by GCinSC2 View Post
Folks,
Suggestion.
Gary
I would also suggest taking some rubber hose, slit it lengthwise and zip tie them around the brake hoses in the areas of potential contact with the frame during suspension travel.
-Rich-
Old 11-14-2017, 06:50 AM   #38
GCinSC2's Avatar
Rich,
That is an option and is a fairly common feature on hoses in possible abrasion areas.
This trailer had the recalled hoses previously and this fall just got 2 new axles at JC.
These hoses were rubbing the frame.
The hose design can be routed in a non contact arc back to its fitting. These were rotated inward pointing to the frame, rubbing.
Gary
S/OS #001
Old 11-14-2017, 08:42 AM   #39
dznf0g's Avatar
Oswego , Illinois
Rich,
Gary
I get it. I still don't trust any hose within about 1/2" of any potential contact point. Since axles/calipers move around a lot during travel...and I can't see them while in motion, I perform the old "belt and suspenders" activity. Also, as you may remember, I used a readily available automotive part number replacement hose and an adapter from hose to caliper. IIRC, the automotive hose was 1" longer than the OE AS/dexter hose.
-Rich-
Old 11-14-2017, 08:54 AM   #40
Mollysdad's Avatar
Great idea!
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
