Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 06-16-2005, 07:27 PM   #1
kabila
Profile:
Brake rattle
I have a '78 Airstream Excella 500 and I'm wondering where to buy the disc brake pads. My pads are not totally worn out yet, but there may be 20 percent left. I have a lot of rattles in the brakes at low speed and I pulled a wheel to check it out. What I believe is that the rotor grabs the pads and it pulls the caliper up and the caliper hits the upper portion. I've pulled it over 1000 miles this spring, so I don't think it's a safety issue. If I replace the pads, maybe the rattling will go away. Does anyone have any comments or experience with brake rattles?
Thanks for any information on the rattles and pads.
William Kallmer
Omaha, NE
kabila is offline   Reply With Quote
Old 06-16-2005, 09:44 PM   #2
silverleeper
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
I'm no expert...Just getting that out of the way . It sounds like the spring clip is missing. The is a slightly bent piece of metal that acts like a spring between caliper and the bracket that hangs on to it. If your caliper is riding loose it will chatter... Hope this helps Lee
silverleeper is offline   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 09:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 07:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 06:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
