Old 05-30-2007, 12:46 PM   #1
1958 18' "Footer"
los angeles , California
brake question PLEASE HELP
i am two days from purchasing a 58 airstream 18 foot model. The current owner says it does not have or need brakes because it is very light and easy to tow. My tow vehicle is an 07 fj cruiser 6 cyl. I need opinions from the experts. Please help clock is ticking.
airstreamer is offline   Reply With Quote
Old 05-30-2007, 12:57 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Brakes would be better. You could tow cautiously w/o them, but a lot depends on how far you need to go. Definitely low speeds.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-30-2007, 01:04 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings and welcome to the forum! A 1958 AS is probably a good canidate by this time for a new axel, so if I were purchasing the trailer I would plan on installing a new axel with electric brakes. It's more of a matter to control of a trailer in an emergency. Could you without brakes, sure idiots do it all the time. Should you, not in my honest opion. But hey, this is what the forum is all about. People sharing their ideas and thoughts.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 05-30-2007, 01:05 PM   #4
1958 18' "Footer"
low speeds?? What does that mean 55 mph. I am in los angeles and my standard trips will be santa barbara to san diego
Old 05-30-2007, 01:11 PM   #5
1958 18' "Footer"
It has a new axle just no brakes. What is an aprox. cost for brakes?
Old 05-30-2007, 01:18 PM   #6
Excella CM's Avatar
Venice , California
I was referring to towing to get it home and then to put brakes on ASAP. I agree with others that brakes are a must for general use. Brake units are about $50-100 per wheel, plus a controller for the truck (@100) and some wiring and a break-away switch. Literally the cheapest insurance you can AND SHOULD buy.
Old 05-30-2007, 01:20 PM   #7
7xp
Santa Maria , California
Airstreamer
Here is a site that shows the brake laws for all the states, I don't know how current it is but it is AAA compiled data. Hope this helps..."Mac"
state brake laws
7xp is offline   Reply With Quote
Old 05-30-2007, 01:25 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
What is an fj crusier?
>>>>>>>>>>>>>>Action
Old 05-30-2007, 01:28 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I found it. It is a Toyota. It is rated to tow 5000 pounds. Make sure your trailer is under 5000. Actually under 4500 would be a better place. And for most states brakes are required on towed loads over 3000 pounds.
If it weighs under 3K #'s, brakes could be left off. And they would make a difference in a panic situation.
>>>>>>>>>>>>>>>>Action
Old 05-30-2007, 01:44 PM   #10
2005 22' Safari
1960 24' Tradewind
>>>>>>>>>>>>>>>>Action
Actually, the 5000# is total weight which is supposed to include anything placed in the trailer and anything placed in the tow vehicle minus the driver.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 05-30-2007, 02:14 PM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
My source shows the 5000# figure includes the total towed load. (IE max weight of trailer and contents of trailer) Nothing to do with the tow vehicle.
>>>>>>>>>>>>>>>>>>Action
Old 05-30-2007, 04:38 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Northern has 12" brakes for $139/pair, and drums are about $80/each. I don't think you need more than 10" brakes, that is just the ones I was looking at for ours when I found your question.
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
