Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-08-2009, 07:15 PM   #1
Profile:  1963 19' Globetrotter
Moline , Illinois
Brake question
I've installed new brake magnets and try as I might I can not get the wire grommet to go back in the drum . Is there some trick to installing this thing or could the wire jacket on the new part be a little thicker and the grommet is just not going to fit? It didn't looked damaged when I removed it. If all else fails can I just use a regular rubber grommet and a dab of silicone where the wire goes through the drum.
63air is offline   Reply With Quote
Old 10-08-2009, 07:58 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you are talking of the hayco connector try inserting it from the back side of the backer plate and squeezing it with a pare of channel lock pliers as you push it into the hole. I say channel locks because the jaws can be opened so the jaws are just slightly bigger than then the hayco connector and thus the pliers close the hayco rather than slip off the connector.
This also works for removal squeeze and pull out when removing.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Brake Question Skycop Brakes & Brake Controllers 1 06-18-2009 08:59 PM
brake question PLEASE HELP airstreamer Brakes & Brake Controllers 11 05-30-2007 05:38 PM
Brake question mtnman All Argosy Trailers 13 12-11-2005 09:42 AM
brake/axle question Chuck Brakes & Brake Controllers 9 09-09-2004 05:28 PM
Brake Controller Question Rickk48 Brakes & Brake Controllers 3 03-17-2003 04:30 PM
