I have a 1974 Ambassador(new to me)--I can not get power (electricity) to my brakes, I tried putting 12 volts right to terminal receiver but got nothing, tried continuity check from terminal to rear brake wires, front to back got nothing. If I put power to wires right at the wheels they work. Sounds like a short somewhere in between, Any suggestions? Thanks for any advice.
Can not find any such patch anywhere under front of trailer. Seems like wires go to left(drivers side) from what I can see from behind couch. I have put power right to LR wheel and it seems like it powered all the other brakes. Does that sound right?
Mike
Your trailer has an open circuit to the brakes.
Underneath the front end of the trailer, you will find about a 12" X 12" patch.
Remove that patch. You will find wires spliced together. Continue your continuity checks from there.
Look some more. Every Airstream has that plate, unless someone has replaced some of the underbelly.
That is where the 12 volt wires are spliced together.
Tests at that junction will tell you where the problem is.
I would not "assume" by adding a wire from the brakes to the front end. You could, possibly, be wiring in a dead short, should the brake open circuit suddenly decide to fix itself.
Look at it this way. If the fuse blows because of a short, you will have ZERO brakes.
In the same set of circumstances, a hot brake line, will still give you some brakes.
The decision is easy.
In the case of a short in an electric brake line, a fused circuit gives zero brakes, BUT, a hot brake line will give you some brakes.
To most safety conscious people, this becomes a very easy no brainer.
Obviously the controller manufacturers will tell you otherwise, but it's "YOU" behind that steering wheel, not them. It's "YOU" that may hit someone, because of "NO" brakes, not them.
Something is better than nothing.
I think that's a tough point to argue against, regardless of circumstances.
