Old 04-23-2004, 06:53 AM   #1
Exclamation Brake Problem
Brake Problem (1987 25)
I jacked up the trailer to check the brakes:
Breakaway - OK
Controller Lever on the Controller - OK
Brake Pedal - NOT OK
I checked the voltage at the wheel while the pedal was depressed I could hear the "tone" but the voltage was only about 1/2 a volt. When I checked the voltage using the Breakaway it was 12 and Controller Lever was 9.5 - HELP !!
moveinon is offline   Reply With Quote
Old 04-23-2004, 07:19 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Controller is bad
Seen this one before.
Give it up. Brake controller is bad.
Check with "Skip" a member here who went through same problem.
Smily
smily is offline   Reply With Quote
Old 04-26-2004, 07:47 AM   #3
Found the problem!!!
Front wheel magnet, curbside, was shot, I guess causing a short........
Will never know though why the other 3 wheels worked properly when using the Controller lever or the Breakaway switch, as they use the same wiring.???
Old 04-26-2004, 08:00 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
You said it
Same wiring?
Brake controllers can be mysterious.
Smily
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 10:15 AM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Brake Horror Story Mike76251 Brakes & Brake Controllers 4 10-06-2003 11:41 AM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 01:44 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
