Old 09-04-2012, 12:00 PM   #1
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
brake plate mounting bolts
Does anyone happen to know the proper size/thread for the 5 bolts that hold loaded brake backing plate on?
Somewhere in Idaho, 50 miles from Airstream, new brakes, forgot to check bolt size for replacement. Hoping someone knows and can save me another 100 mile round trip hardware run.
Oh, and are stainless steel bolts and lock nuts strong & appropriate for brakes?
Safari64
Safari64 is offline   Reply With Quote
Old 09-04-2012, 02:02 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This will give you some specs. on the bolt/nut combination for Dexter from eTrailer.com...
12" Electric Brake Assembly, LH - 6,000 lbs Dexter Trailer Brakes 23-105
Old 09-04-2012, 11:19 PM   #3
Safari64's Avatar
1964 22' Safari
3/8-24 x 1 1/4"
That's it...Thanks a lot!
Old 09-05-2012, 04:16 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Use the grade 5 or 8 bolts. Grade 5 have three bumps on the top of the heads and grade 8 have 6 bumps.
Old 09-06-2012, 12:36 PM   #5
Safari64's Avatar
1964 22' Safari
Thanks!
The Dexter specs gave the needed size. Big help.
I installed new Grade 5, 3/8-24 x 1 1/4", bolts with Grade 5 nuts and new lock washers, new loaded backing plates, bearings, races and seals.
It had studs pressed into the old backing plates instead of bolts (from 1964?).
Machine shop dude measured the drums at "exactly 12 inches", saying "These have never been turned and don't really need it now....had him clean them up just the same. We decided new thinner "China metal" backing plates were probably better off with bolts than pressed studs.
Headed for Alberta Rockies! Now I have real BRAKES!
Thanks for the help.
