Old 03-29-2004, 10:20 AM   #1
Grand Bend , ON
brake parts
Does anyone know what make/size of electric brakes are on the 1980 25' International? I need to source return springs, etc. and supply houses need to know what brake I'm working with. Also, these brakes have the round style magnets - should I upgrade to the ovals?
Thanks!
Jay & Sue
Jay & Sue is offline   Reply With Quote
Old 03-29-2004, 01:53 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Have you looked into just replaceing the whole backing plate. I've seen them loaded for $55.00 each.
Just a Thought.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 03-29-2004, 04:41 PM   #3
ke4pk's Avatar
Images: 8
Most Of The Things You Need For The Brakes Is Available At Any Rv Dealer That Has A Good Supply Of Parts.....common And Quite Generic.
ke4pk is offline   Reply With Quote
Old 03-30-2004, 07:55 AM   #4
1964 26' Overlander
1977 25' Tradewind
My point is why bother with parts when you can get the whole backing plate fully assembled with new parts including the magnets for less than the cost of the piece parts.
Peace
Gary
Old 03-30-2004, 08:40 AM   #5
Grand Bend , ON
Thanks, all. I'm heading to a trailer service dealer today to see what I can get. I think that the brakes might be Dexter ....
We live in western NC, and their seems to be a limited number of distributors close by. I'll balance the part prices against the complete assembly, including freight. Time (labor) isn't a consideration for me right now, as I have time on my hands and am repacking the bearings anyway.
Jay & Sue
Old 03-30-2004, 08:41 AM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Gary, you make an excellent point. However (you knew it was coming ), in my case, I had one broken return spring in an otherwise functioning system. I would have been torqued if I had had to pay $55 for a spring.
But that is not why I posted. Replacing one backing plate is fine IF your other backing plate buildups are identical to the one you are replacing. Everything I have read in the forum indicates the ones being made today are far superior to the four on my '67 Overlander. I assume superior means they brake more with less current.
So, if I had replaced one backing plate, and left the other three alone, I probably would have had uneven braking. So now I would be up to $220 for a spring.
Its nice to know where to get piece parts
Tom
Old 03-30-2004, 09:01 AM   #7
Grand Bend , ON
Tom - my feeling exactly. I now have a second wheel off, and that adjuster spring is broken, too. As with the first wheel, the brake linings and drums are in exceptional condition. I am thinking that the brakes were actually redone 10 years ago, before the trailer 'sat' in a trailer park. I'm guessing that the adjuster springs broke as soon as the PO moved it. The trailer was towed approximately 250 miles last September, and we've been working on it since January.
Your point about the updates is also well taken, as I've read about newer 'oval shaped' magnets vs. the round ones that are installed on it. And of course, that's where things get trickier in deciding how far to go with piece parts vs an assembly. I'm not terribly impressed with the brake effectiveness in general. Although there is no 'pulling' to one side or the other, and no grabbing, I feel that the brakes should be 'stronger' than they are. I'm looking at the magnets now, and it seems to me that the friction surface is only marginally above the screw heads. I'm not sure just how much wear is advisable before replacing the magnets, but since I am taking everything apart anyway and there may be a better component (magnets) available now vs 25 years ago, maybe I should consider replacing those, too.
I can get a complete spring set for about $4 per wheel. Plus magnets (possibly) - that is what I'm weighing against the assembly cost. Again, my time is 'free' right now, and I've done lots of brake work over the years - albeit hydraulic brakes.
Jay & Sue
Old 03-30-2004, 01:39 PM   #8
1964 26' Overlander
1977 25' Tradewind
Tom, Jay and Sue
I hear what you're saying, I would only go the loaded backing plate route if I new the springs, magnets, and shoes were in bad shape and should all be replaced. Just one or the other I probably wouldn't replace the assembly.
Peace
Gary
Old 05-14-2004, 09:50 PM   #9
Desert Fox
1985 31' Sovereign
Tucson , Arizona
05-14-04
Hi Gary
thanks for the info on Dexter brake assembly. They were only 49.90 each. On my 1985 A.S. the round magnets were gone and when you figure out the price on
seperate parts the brake assembly is the only way to go. Dexter brake are easy to install and they have dealers all over the country. They also sell on the net. russ
RUSSELL is offline   Reply With Quote
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Source for brake parts? 74Tradewind Brakes & Brake Controllers 9 06-11-2002 04:26 PM
