Old 02-01-2012, 01:24 PM   #1
1986 31' Sovereign
Miami , Florida
Brake Magnets - mildly confused
So, had all four wheels off today for the annual bearing repack.
Noticed that all four brake magnets are more or lessevenly worn but also noticed that, by design, the metal outer jacket of the magnets wears along with the brake material in the center. So, how do I know when the magnets are done?
When they are worn down to the little screw heads? Is there a finite thickness measurement?
Help would be gratefully accepted.
Mike
Old 02-01-2012, 01:35 PM   #2
Mike
Mike.
When round magnets wear down to the TOP of the 3 brass screws, there done.
If you go beyond that, they will wear into the wire coil.
When that happens, you will have an electrical short facing the controller.
Then, anything can happen.
An electrical short, of any kind, is never OK.
Old 02-01-2012, 01:52 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
If you can see the wires in the coil, it's shot.
As you're probably aware, it's best to replace the whole brake assembly with new loaded backing plates, which will include shoes and magnets.
Old 02-01-2012, 03:03 PM   #4
Images: 59
An electrical short is a good thing, if you're the one holding the Tazer.
Not so good on the other end.
Old 02-02-2012, 05:56 AM   #5
1986 31' Sovereign
Miami , Florida
Thanks, all
mike
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
