Old 07-28-2015, 05:03 PM   #1
1976 31' Sovereign
Lost somewhere in , Canada
Brake magnets all dead?
Hey folks,
I just picked up a 76 sovereign. In going over the wiring a noticed that it did not have a breakaway switch at all. Then in testing the brakes I'm finding that the brake magnets all seem to be dead?
Is this common? I've tested the brakes with the battery wired direct to each brake (not solid wired of course) and none of the magnets will engage.
After hub removal the magnet wont even hold a screw driver when power applied.
Chris
quicker is offline   Reply With Quote
Old 07-28-2015, 05:16 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When I got my 64 Bambi II. Same problem. I was getting a new axle, hubs and brakes anyway so no big deal. Foley Airstream totally rewired the brake system and installed a brake away switch.
MICHAEL
Old 07-28-2015, 05:32 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
If you have supplied 12v and the magnets are not energizing then they are bad. Install a new breakaway switch, new magnets and go on for a temp fix if you are getting a new axle which probably needed. Magnets are around $25ea and breakaway switch about $20.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-28-2015, 05:34 PM   #4
1976 31' Sovereign
thanks guys. new breakaway already installed. Getting magnets tomorrow. Do the new oval magnets fit right in even though the center hole is no longer round in the magnet like mine are?
Yes planning on new axles this winter so just trying to go temp fix for now.
Old 07-28-2015, 06:10 PM   #5
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Yes, that is correct. Take some emory cloth(sandpaper and clean the rust/dirt off the inside of the brake drum. Check your wiring-older trailers will not match up with today's connectors. Diagrams are available on here if you do a search.
Bruce
Old 07-28-2015, 06:11 PM   #6
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Oh and welcome to the forums and airstreaming.
Bruce
Old 07-28-2015, 08:24 PM   #7
1976 31' Sovereign
Thanks. All re-wired to new configuration.
Old 07-28-2015, 09:06 PM   #8
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
i had the same issue with my 1975 argosy. the magnets seemed dead until you spun the drum and then they grabbed right away. doesn't really make much sense to me but stops the trailer fine.
AlbertaBound is offline   Reply With Quote
Old 08-24-2015, 07:38 PM   #9
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
brake wiring
thanks for noting that vintage plug wiring is different than modern setups! I had problems because when I changed my trailer plug wiring to match a 2006 suv plug, I had problems in both running lites and brakes. I had to go under the 65 caravel, take off a small panel and match the wire to the function . the biggest problem is that the brake wires are YELLOW IN THE FRONT OF THE TRAILER AND GREEN GOING INTO THE REAR BRAKES! the BLACK WIRE turned out to be the back-up lites. When I tried to find out if the charge line was the LITE BLUE WIRE OR THE DARK BLUE WIRE, I traced them to to the jumble of wires inside that passes for the conjuntion box and found that the factory had carefully painted them ALL zolatone white!!
other than that, everything works fine. joe in minnesnowda
joqin is offline   Reply With Quote
Old 08-24-2015, 08:11 PM   #10
1974 Argosy 20
Kooskia , Idaho
Ah, the joys of working on an old Airstream. Factory funny's or PO fun or just plain different. Glad you got it worked out.
Testing brake magnets goshawks00 Brakes & Brake Controllers 2 11-21-2011 07:48 AM
Brake magnets kingfisher24 Brakes & Brake Controllers 11 05-18-2011 10:22 AM
Brake magnets 1976 Sovereign Splitrock Brakes & Brake Controllers 2 07-31-2010 01:29 PM
Grease on brake magnets lbrodsky Brakes & Brake Controllers 43 11-25-2006 07:06 PM
Need a couple of old brake magnets Excella CM Brakes & Brake Controllers 1 07-02-2006 07:47 AM
