Old 05-17-2011, 06:41 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
Brake magnets
2008 25fb safari....had my brakes serviced at JC yesterday.....they replaced the magnets and that is all......trailer had about 40000 miles on it.....do these magnets operate the brake shoes.....
will someone explain the brake operation to me
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 05-17-2011, 06:59 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Here is a link to a video on brake installation. You can see the magnet and the actuator arm. When current is applied the magnet grabs the inside of the drum causing the actuator to move and the shoes to expand. Old technology, but very simple and effective.
YouTube - etrailertv's Channel
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-17-2011, 06:59 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The brake magnets ride along the face of the drum. When they are energized they grab the drum and the spinning of the wheel causes them to move. That movement is transferred to a cam between the two brake shoes which causes the brake shoes to move away from each other and engage the surface of the drum.
Name:	electric brakes.jpg
Richard
Old 05-17-2011, 07:06 AM   #4
2005 30' Classic
Burlington , Ontario
I'm sure that others can give a more understandable and complete explanation than mine but here goes .......
The brakes on your trailer (other than newer trailers with disc brakes) are basically similar to standard drum brakes on a car - with one big difference.
Instead of using a hydraulic slave cylinder to force the brake shoes into contact with the brake drum, the trailer brakes employ electromagnets on a lever arrangement to force the brake shoes out.
The magnets are arranges so that they face the inside (vertical) face of of the drum.
As you apply brakes, the trailer brake controller in your car sends current to the electromagnets which causes them to be attracted to the inside face of the drum. Since the drum is rotating, it tends to drag the magnet around in the direction of rotation.
That dragging force is then translated through the lever mechanism to which the magnets are attached and causes the linkage to apply outward pressure, forcing the brake shoes in contact with the drums.
The face of the electromagnets will eventually wear due to their contact with the drum, at which time they need to be replaced. They last a long time. I've never yet had to replace them on trailers we have owned.
That's my understanding anyway! Clear as mud?!
Brian.
Old 05-17-2011, 07:19 AM   #5
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Brian.
Thanks for the explanation. Even though I've done my own car brakes for 35 years and repacked/adjusted the trailer wheel bearings every year, I never quite understood how they worked. Great explanation, now I understand it.
SilverCottage is offline   Reply With Quote
Old 05-17-2011, 09:06 AM   #6
thanks
The only problem I see, is that electric brake magnets only last about 20,000 to 25,000. At 40,000 miles I would be surprised if the drums were not scoured.
The shoes can and do usually outlast the magnets about 2 to 1, in miles.
Old 05-17-2011, 12:10 PM   #7
Islander
good thoughts
i thought, the more i thought that that is the way they worked....maybe 40000 is stretching the trailers mileage but 30000 is pretty darned accurate....
as i say the service center at jackson center did it and i questioned the lack of need for shoes and they said everyting else looked fine......strange to me however
and even stranger...the magnets were not really that worn...i saw them.....but they were beginning....and so i had them replaced
Kingfisher24
WBCCI 2541
4CU
Old 05-18-2011, 08:22 AM   #8
LONDON , ON
For the untrained eye, how do you know when the magents are worn and need to be replaced?
Old 05-18-2011, 10:19 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Think of the magnet as a disk brake pad, the more of the magnet that is present, the more efficient it is. On our old 63 I noticed a lot of brake loss at about 50% ware.
On our Classic the wiring gave out long before the shoes or magnets.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 05-18-2011, 10:31 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I believe there is a aluminum philips head screw in the face of the magnet. The rule of thumb says to replace the magnets when you can no longer see the cross in the screw.
Old 05-18-2011, 10:59 AM   #11
Originally Posted by dwightdi View Post
cross in the screw.
Come on man...I just got back,
Amanamus
"Tahawus"
Old 05-18-2011, 11:22 AM   #12
Goal15's Avatar
Holly Lake Ranch , Texas
No wonder people missed you
I can see why people were wondering where Bob Cross had gone! Excellent retort, Sir.
Goal15 is offline   Reply With Quote
Brake controller incompatibility? Flying Gypsies Brakes & Brake Controllers 7 10-31-2011 01:41 PM
RF causing brake controller malfunction nm1oqrz Phone, CB & Ham Radio 6 04-12-2011 07:03 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 08:43 AM
