Old 07-17-2013, 01:24 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Brake magnets?
How do i know if the brake magnet on my '59 tradewind needs to be replaced? It seems to be gripping ok when power is applied. My concern is the face of the magnet looks rather worn and ground down. I see metal. Is this normal? Pic attached.
steveirving is offline   Reply With Quote
Old 07-17-2013, 04:03 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The metal showing is normal. when the friction material is worn through or worse you can see see wire where the friction material should be it is replacement time. about that time the slots in the 3 screws will be gone also
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-17-2013, 06:40 AM   #3
1959 24' Tradewind
Quantico , Virginia
Images: 11
Thanks!
