Old 05-08-2005, 09:56 PM   #15
Loren's Avatar
Thanks for all the suggestions.
We just got home this evening from our week-long jaunt. The first priorities will be to repair the new water leak in the sewer pipe between the dump valves and the hose connection, and to repair the brake problem.
The brakes worked fine all the way home from Chicago (about 350 miles), but I intend to try to duplicate the problem while I still have the rig hooked up. I hope I can, since I don't want to duplicate the problem on the road next month.
I like the idea of just replacing all the magnets. I should be able to do that for a reasonable price, even for six brakes, and if the problem is a magnet, then that would obviously save a lot of troubleshooting time. I'll be checking the price of magnets tomorrow (Monday, 9 May).
Thanks again for all the help.
Loren
Loren is offline   Reply With Quote
Old 05-09-2005, 01:54 PM   #16
Loren's Avatar
Update
I got the inductive ammeter out and measured the current at each brake. I couldn't find the problem.
I connected the meter to the appropriate wire, then pulled the emergency breakaway cable to set the brakes. I then quickly read the current and reset the emergency breakaway. Here are the readings (in amps):
LF: 2.9
LC: 3.0
LR: 2.9
RF:2.9
RC: 2.8
RR: 2.7
I don't see anything there to indicate a fault.
While I was talking to the guy at BrakeSmart, he told me that many brake short fault messages are triggered by poor wiring at the cable. I recently installed a Pulliam Pull-Rite hitch, and that required an extension of the trailer connector. I wired up an extension cord to complete the installation.
Since I didn't see any problem at each brake, I dismantled the plug that I wired and inspected it. I didn't see anything wrong, but went ahead and re-connected all the wires. A couple of connector screws were not as tight as I would have liked, but otherwise everything seemed okay.
I am now unable to duplicate the problem, so maybe there was some single strand of wire in the plug that crossed to an adjoining screw. That would probably be enough to cause the fault indication. I sure hope that's the case, since I am not going to do any more with this until I pull the trailer again.
I inspected the wiring that leads from the brakes into the trailer bottom. It is well protected, being two single wires, each individually insulated, that are formed into a cable by another outer covering. It looks like a small Romex cable.
If the brake short fault shows up again the next time I tow the trailer, I'll probably replace all the magnets or backing plates. I called our local Dexter axle supplier and the magnets sell for $24. An entire backing plate is only $66, and you get new shoes with that. These brakes are not worn much, so I really don't want to rebuild them yet, but I will if I have to in order to solve this problem.
Thanks again for all the great suggestions.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Old 05-10-2005, 07:46 AM   #17
Loren's Avatar
Update
One more update:
Since the trailer was still hooked to the truck after I finished checking the above items, I took it for a test drive to see if I could duplicate the brake short. I drove about 12 miles and the fault never showed up again.
The only thing I did that may have made a difference was dismantle and re-assemble the electrical plug on the trailer hook-up cord. I'm hoping that I have fixed the problem. We'll know more in a month or so after our long summer trip.
Loren
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
