Old 06-29-2005, 01:43 PM   #1
2003 19' Bambi
Vancouver , Washington
Brake lockup?
The thread about brake controllers got me thinking about something: I have a Tekonsha Voyager brake controller. The setup instructions say that if the trailer brakes are working correctly, then when the controller is adjusted all the way up I should be able to lock up the trailer tires by sliding the manual control all the way over. (Obviously you wouldn't leave it adjusted this way -- it's just part of their adjustment routine)...
Anyway, I have found that although it will pull pretty hard, I can't actually lock up the trailer brakes on dry pavement. This doesn't bother me -- during towing, the braking seems pretty good.
But is it unusual? This is on a single axle 2003 Bambi with about 5k miles. Maybe I should check the mechanical condition of the brakes? Or maybe the controller isn't applying full power?
erik.ness@hp is offline   Reply With Quote
Old 06-29-2005, 01:49 PM   #2
Contrary to opinion, electric trailers brakes must be adjusted at least every 10,000 miles, or sooner.
The adjustment compensates for the wear.
Old 06-29-2005, 01:55 PM   #3
Somewhere , Indiana
No lock up!
But is it unusual?
Erik,
This may sound a bit strange but – most trailer brakes (electric) are designed NOT to lock up. Lock-ups can be dangerous!
Regards,
Henry
axleman is offline   Reply With Quote
Old 06-29-2005, 02:08 PM   #4
1974 28' Argosy TT
stinkytwinky's Avatar
1975 28' Argosy 28
Hinsdale , New Hampshire
Send a message via Yahoo to stinkytwinky
I have a 1974 28' Argosy twin axle, and I can get my brakes to lock-up, and Andy, how do you adjust the brakes. I will look for a forum on the subject while I wait for you to direct me to one.
1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. )
1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
stinkytwinky is offline   Reply With Quote
Old 06-29-2005, 02:15 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
I am not Andy, nor did I stay at a Holiday Inn Express last night, but I think I can help you. Trailer brakes are adjusted basically the same way rear drum brakes are adjusted on a car. There is a star adjuster, that moves the brake shoes closer to the drum. Most adjustments are through a slot in the backing plate with either a special adjuster wrench, called a spoon, that looks like a bent flathead screwdriver, or a flathead screwdriver. Some use a bolt with a jam nut to adjust brakes, but I haven't seen too many of those.
Old 06-29-2005, 02:33 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Contrary to opinion, electric trailers brakes must be adjusted at least every 10,000 miles, or sooner...
Are you sure about 10,000 miles? I thought it was considerably less.
The last vehicle I owned with manual adjustment brakes was a VW Beetle, and I adjusted the brakes like every 6,000 miles. But I did drive a bit "differently" in high school.
Tom
Old 06-29-2005, 02:38 PM   #7
TomW's Avatar
1967 26' Overlander
Originally Posted by overlander63
I am not Andy, nor did I stay at a Holiday Inn Express last night, but I think I can help you...
Slept at home last night too and I will add that there are different interpretations of the "right" adjustment.
I dial the stars out until I just hear the shoes making contact. At this point, the shoes may not scrape for a complete turn. Other people like to hear the brakes drag for a full turn.
Tom
Old 06-29-2005, 02:43 PM   #8
Somewhere , Indiana
Talking Brake Adjustment
Tom
Tom,
Different axle manufacturers may have different service guidelines. I have seen “General Maintenance” instructions call for a brake adjustment at 200 miles and then every 3000 there after.
Just my two cents.
Regards,
Henry
Old 06-29-2005, 05:02 PM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One factor that affects the ability to lock up the brakes is your gain control on your brake controller. I think my instructions for my Jordan controller is to drive slowly on an flat unbusy street or parking lot at about 25 mph. Then you use the manual control to set the trailer brakes to full power. You adjust the gain so that the trailer brakes are almost on the verge of full lockup under full power from the manual control. I know in the adjustment process when the trailer was new, I could get the trailer into lockup.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
