Old 06-01-2011, 08:56 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Brake lights, brake controller not functioning
Trying to figure out where to start to locate the problem, but brakes/brake lights are not functioning. My Prodigy P2 is giving me a "not connected" message, and my TV (a Touareg) is telling me to "check trailer lights). I'm fairly certain the problem does not lie with the controller or the TV as I hooked up to another Airstream and it worked fine. Fuse? Short? I'm baffled.
adwriter73 is offline   Reply With Quote
Old 06-01-2011, 09:01 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The brake lights are not connected to the brake controller, but connect directly to the wiring of the TV. I would suspect from the multiple symptoms that your connection from the trailer is not wired correctly. The pin assignments are different for various generations of trailers and yours may not be correct for the pin assignments in your TV.
Richard
Old 06-01-2011, 09:13 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
As Richard noted it probably was the Female connector on the AS, what year was the AS you connected too? One of the pins on your trlr connector is the battery charge line take a jumper and test each pin, see if they match the TV.
Trailer Wiring Diagrams | etrailer.com
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 06-01-2011, 09:40 PM   #4
Ottawa , ON
On our rig, those symptoms were remedied by looking up in the TV's owners manual, finding which fuse position was designated for the trailer equipment, and putting in the fuse that the hitch installer had forgotten.
Voilà, everything worked!
Old 06-01-2011, 10:18 PM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Does your sovereign have led tail lights? If so there may not be enough resistance for the Touareg to recognize them.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-01-2011, 10:50 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Simple: They didn't have a Prodigy in 1978. Gotta match up the 1978 umbilical pattern to your new fangled television TV thingy
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-02-2011, 08:36 PM   #7
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I checked the wiring against the diagrams, and it all matches. I also took my TV to the dealer to see if there was maybe a malfunction with the wiring harness. It all checked out ok. So, I decided to cleaned the connector pins with some WD-40. They were a little dirty, but not much. When I plugged it in, suddenly everything worked...for about 5 min. So, do you think something isn't getting a good connection or something isn't grounded? I'm not quite sure what to do next. Maybe get a new 7-pin cable?
Old 12-05-2013, 01:52 PM   #8
Brokerchris's Avatar
2013 23' FB International
Aliso Viejo , California
Having the same problem. What was the remedy?
Brokerchris is offline   Reply With Quote
Old 12-05-2013, 02:45 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On my trailer I had a failure in the connection to the 7 pin plug on the trailer. The connection is by screw terminals between the wire and the plug. It can corrode and if it gets pulled on it can have a wire or so break or come loose. I think a new plug would be a good way to proceed. You can get them at Walmart.
Old 12-05-2013, 05:17 PM   #10
Lost in America
mojo's Avatar
What is your tow vehicle?
2017
Old 12-05-2013, 06:20 PM   #11
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
Bad ground or bad connection with brake circuit in plugin. Nothing other than that. WD40 cleaned it and it may not happen again. NOT ROCKET SCIENCE.
panheaddale is offline   Reply With Quote
Old 12-05-2013, 09:29 PM   #12
THANKS- Turns out WD40 and duct tape only solves 91% of problems out there- VW hasn't "Enabled" the charging pin on the car for the 7 way adapter so it is more than your issue. So effectively the OEM towing wires only work for lights and nothing more. Brake controller and charging to the trailer do not. So, the Touareg will sit at the dealer tomorrow while they do some rocket science with their ECU programer and make it work.
Old 12-05-2013, 09:30 PM   #13
2012 Touareg TDI
Old 12-06-2013, 08:10 AM   #14
1964 26' Overlander
1968 30' Sovereign
lighs not working.
My bad I dind't see the quit working after 5 min. on the OP I would check connections on plug maby replace it and check fuses to make sure any are not blown. If fuse is blown may be a short in connector or trailer.
Brake controller incompatibility? Flying Gypsies Brakes & Brake Controllers 7 10-31-2011 12:41 PM
Baffled by P2 Brake Controller Goal15 Brakes & Brake Controllers 13 05-15-2011 08:11 PM
RF causing brake controller malfunction nm1oqrz Phone, CB & Ham Radio 6 04-12-2011 06:03 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
2010 RAM 1500 Integrated Brake Controller Mifair Brakes & Brake Controllers 1 01-16-2011 05:07 PM
