Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-06-2003, 03:16 AM   #1
Mike76251
Mike76251's Avatar
Profile:
Brake Horror Story
Hi all,
Sit back and let me tell you of something that happened to my AS a couple of years ago.
I was going cross-country in a BIG hurry (had 3 days to do it) in October and had fair weather most of the way.
I say most of the way because when I got to Flaggstaff, AZ (high elevation) I hit black ice.
I found my Airstream handled the ice well but NOT the snow.
I went through several snow piles trying to find a place to park it for the night.
I never did find a place to park it (KOA was iced over) so I hit a rest area for a couple of hours of sleep.
When I got up and hit the road again I noticed my brakes didn't work as well.
I couldn't stop until I hit northern California 'cause I was running late.
I parked it in a RV park in N California and crawled underneath,
I found the snow had ripped out all the brake wires but one.
The wires were tucked up nice before I left for the trip but the snow still got them.
I wound up pulling the AS through downtown LA traffic with only one brake working!
That one brake doing all the work had completely wore the pads down to nothing.
I wound up putting all new brake assemblies on all four axles and routed the new brake wires OVER the axles.
Moral of the story........check your brake wires often esp. after snow!
Mike
Mike76251 is offline   Reply With Quote
Old 10-06-2003, 05:42 AM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Now I am dealing with a older coach with a different axle arangment but all our brake wires are in the belly pan. The come through the frame rail and only have about 6 inches of exposed wiring that is still fairly well protected.
Did the wires end up under the coach is some sort of repair?
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-06-2003, 07:08 AM   #3
trumpwer
79 SLY
trumpwer's Avatar
Profile:  1979 31' Sovereign
Fairview , Montana
Images: 46
Mine are under the pan also. It used to have the hydralic brakes, PO changed it to electric. They dont hang, but they are under the pan.
The Trumpowers
1979 SLY 31'
1979 GMC 4 door with s/c camper shell
trumpwer is offline   Reply With Quote
Old 10-06-2003, 07:39 AM   #4
Mike76251
Mike76251's Avatar
Profile:
My brake wires were hanging about three inches under the belly skin.
The old brake wires were too short to let me route them over the axle and I couldn't get solder to stick to the old wires so I couldn't make them any longer.
I thought that would be enough for the trip but it turned out not quite enough.
The new brakes had plenty of wire to let me re-route them so the problem should be fixed.
Just get your wires as high as you can and check them after high weeds, sand, or snow.
Mike
Old 10-06-2003, 12:41 PM   #5
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
suggestion
At most auto parts stores (Auto Zone & Checker) there is a wire loom cover that can be purchased. Usually it comes in 10 foot sections in a varity of colors. Including shiny silver.
You can use it to cover a bundle of wires and offers good protection. Cut to length and slide over the wires.
>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 11:15 AM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
Brake controller hook-up Dimick Brakes & Brake Controllers 7 05-15-2003 09:57 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 02:44 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
