Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-12-2004, 07:55 PM   #1
Airstream 1975!
Airstream 1975!'s Avatar
Profile:  Baghdad , Iraq
Question Brake drums
OK I have questions!! I replaced my brakes and was wondering if the drums should be turned or replaced. If they need replacing where do you get them from?? Does anyone know the proper size drums for 12" brakes? Some places have different spindle sizes. What would the spindle size be?? What are suitable bearing replacements??
Airstream 1975! is offline   Reply With Quote
Old 03-12-2004, 10:09 PM   #2
danesh
danesh's Avatar
Profile:
I just recently repacked my wheels when i noticed that one of the drums needed to be changed. I took the drum and the bearings to our local RV dealer and they found the right size. Sometimes it is better to put a new one in place of turning a drum.
85 sovereign
danesh is offline   Reply With Quote
Old 03-12-2004, 10:23 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Brake drums
1975,
Lots of questions. Do you know the manufacturer of the drums?
Should the drums be turned or replaced?
This is somewhat subjective. Are they corroded or cracked or scored? If so, have a brake shop check the diameter and turn them if they are under the maximum diameter marked on the drum. Also check the armature (the flat inside surface) that the magnet acts against. If it is warped or scored you may want to replace the drum.
Where do you get them?
Do a web search on the name of the brake manufacturer. I don't have a '75 Overlander, but some of the manufacturers are Dexter (www.dexteraxle.com) and Reliable Tool (www.reliabletool.com).
You can also order parts from Low Cost Trailer Supplies (www.lowcosttrailersupplies.com)
What are the proper size drums and spindles?
Either take the old bearings to an auto or trailer parts supplier, or buy a cheap caliper and measure them. Once you have the dimensions you can find the proper bearing sets at Low Cost Trailer Supplies website listed above.
Some people will only use Timken bearings. Otherwise you are probably going to get Chinese or Eastern Bloc bearings. Matter of personal preference, cost, and the fact that probably 90% of the trailers on the road today are running on non-Timken bearings.
Non-contributing deadbeat.
Old 03-13-2004, 12:27 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Brake drums
Greetings Airstream 1975!
While I didn't do the work myself on either my '64 Overlander or '78 Minuet, I had two different shops (both have mechanics that I have trusted for service on my RVs for years - - one Airstream and the other Brand X). Both shops recommended the same procedure - - new fully-loaded backing plates, then turn the drums and shoes to match the surfaces. Even on my '64 Overlander, the original drums were still within tolerances and were resurfaced. The matching of the shoes to the drums certainly made the brakes apply much more uniformly and reduced the noise from the system significantly. According to the mechanic who rebuilt the brake system on my Overlander any automitve machine shop that is familiar with trailer brakes should be able to reference the machining standards for the drums - - replacements should be obtainable by matching your current drums if replacements are needed.
Good luck with your brake project!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
