Old 09-30-2010, 11:26 AM   #1
1999 19' Bambi
Phillips , Wisconsin
Brake Drum Removal
I'm working on the brakes on our 99' Bambi and can't seem to get the brake drum off. I've removed the dust cover, then the snap ring and spring, then the zertz disc. Now I'm at the nut with the cotter key. But to remove the cotter key I think the heavy steel cylinder that the dust cover sits on must be removed. Does anyone out there know how to remove that cylinder?
Thanks.............RIC
ricnjane is offline   Reply With Quote
Old 09-30-2010, 12:04 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Ric, This might help you.Repack Trailer Hub Bearings Demonstration Video | etrailer.com.
I not take a pic so the Airforums community can see what you're looking at.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-30-2010, 12:08 PM   #3
tpi
Trabuco Canyon , California
Sounds like you have bearing buddies or the like.
You didn't need to remove the snap ring, spring or zerk fitting.
The "heavy steel cylinder" just needs to be tapped with a mallet to walk it off.
tpi is offline   Reply With Quote
Hadco Brake Drum rfcjr Brakes & Brake Controllers 3 10-22-2011 08:19 PM
Brake Drum Adjustment Devoman Brakes & Brake Controllers 20 01-06-2010 05:38 PM
Cracked Brake Drum cosmos Brakes & Brake Controllers 3 04-12-2008 03:09 PM
Need easy way to take brake drum off..>> Mrcrowley Brakes & Brake Controllers 18 05-23-2006 08:44 PM
Need Help –Brake Drum HOT! Mookie Brakes & Brake Controllers 12 05-21-2005 09:36 AM
