Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-11-2006, 05:52 PM   #1
trvler
Profile:  2006 31' Classic
Kingston , ON
Brake delay on new 31' Classic
I've just bought a new 31' Classic, and tow with a 1500 Suburban and use a Masterbrake controller. The brake actuator is "Actibrake". There is a 1+ second delay between hitting the brakes in the TV and brakes activating on the trailer. Is this typical? and if so, seems quite dangerous. Anyone have any solution?
trvler
trvler is offline   Reply With Quote
Old 11-11-2006, 11:19 PM   #2
wheel interested
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 117
Hi Trvler, congratulations on your new Airstream.
I'd call Masterbrake and Actibrake and speak directly to them. Then perhaps your dealer, as a practical choice, but not necessarily the definitive answer unless they are knowledgable of your particular set-up, afterall they did send you out that way.
If it were Prodigy controller I would try setting the boost up to apply more trailer brake at the onset.
Do you think the heavier trailer is pushing the truck before slowing? Do you have to change your brake controller settings from your previous (lighter?) trailer?
Cj
Joy to the world
Joy to you and me
wheel interested is offline   Reply With Quote
Old 11-11-2006, 11:31 PM   #3
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Missoula , Montana
No, this is not right.
You need to set the gain or boost so the trialer brake activate at the same time or just before the TV brakes.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 11-12-2006, 07:09 AM   #4
markdoane
Profile:  , Minnesota
Images: 59
trvler,
1. Did you do the 'Brake Synchronization' procedure?
2. Have you bled the brakes?
If neither of those helps, then I think you are experiencing the .6 sec delay as the brake actuator spools up and builds pressure in the brake line.
Unfortunate, but it is a feature of electric/hyraulic actuators.
Non-contributing deadbeat.
Old 11-12-2006, 08:21 AM   #5
trvler
Kingston , ON
Brake delay
I did talk to Actibrake, and bled the brakes as they suggested. No difference. So have also come to the conclusion that this is just the inherent delay that the actuator needs to build up pressure.
The smartbrake controller doesn't seem to need to "synchronize" as it did with my old 25' Safari with drum electric brakes - not sure why, and I can't seem to find a number which works for Masterbrake (or a webpage for that matter - www.masterbrake.com no longer works, for me anyways). When the brakes do kick in, it's beautiful.
If this is inherent to the device, I'm surprised no one has been in an accident yet - in one second you travel about 90 ft at 60mph. But what I really notice is the healthy shove I get on the rear end when braking on a corner - might also have something to do with the Hensley.
trvler
Old 11-12-2006, 11:04 AM   #6
thecatsandi
Missoula , Montana
Trvler,
You will want to look at the service bullitens on the Active Technologies website. Your controller may no longer be compatable with your new brake system. Prodigy is the one AS used to recommend and many have used it with sucess. I did until my new truck came with built in controller. AS is now recommeding the Jordan controller.
Michelle
Sarah
Old 11-12-2006, 12:19 PM   #7
markdoane
Images: 59
Originally Posted by trvler
. . . The smartbrake controller doesn't seem to need to "synchronize" as it did with my old 25' Safari with drum electric brakes - not sure why. . .
trvler
My comment about schronizing came from the Actibrake manual. I think you need to hold down the manual actuator for 10 seconds each time you plug it in.
Kind of like waiting for air pressure to build up when you fire up the ol' Peterbilt.
Old 11-12-2006, 01:53 PM   #8
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
If mark's right...
Originally Posted by markdoane
My comment about schronizing came from the Actibrake manual...
Geez, it would annoy me if I had to symphonize my brake controller every time it was switched between tow vehicles.
Tom
Old 11-12-2006, 02:27 PM   #9
trvler
Kingston , ON
Brake delay
Thanks for your comments. Michelle - do you experience any brake delay with your 2006 Classic? Perhaps I will need to try out a Prodigy controller, although I hate to give up the Brakesmart.
The alternative would be to try a different actuator - I've read that Sensabrake develops full pressure in 1/3 second, whereas Actibrake takes about 1 sec to develop full pressure.
trvler
Old 11-12-2006, 03:23 PM   #10
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
No problem here
My Classic 28 was modified from drums to discs last summer. While it is true that the Actibrake synchronizes each time the brakes are applied, but I have found the delay to be unnoticeable. The synchronization time, as I understand it, is in the range of milliseconds.
I find that the disc brakes are very effective and I can never sense the trailer is even back there when I brake.
I do have the Prodigy set to give the initial boost at level 1. For heavy trailers, the initial boost is required.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 11-12-2006, 03:26 PM   #11
Pahaska
Pahaska's Avatar
Images: 12
One more thought
The dealer in Weatherford, TX, that did my conversion drove my truck/trailer for about 20 minutes breaking in the discs and pads. He dragged the brakes until we could smell them. He said that sort of break in is necessary on new discs and pads.
It must have worked ... in the last 6 months, I have touched the controller only once and that was to reduce braking slightly after about 100 miles.
John W. Irwin
Old 11-12-2006, 03:50 PM   #12
wlj1943
wlj1943's Avatar
Profile:  1970 18' Caravel
1995 30' Excella
Mulino , Oregon
Hi all,
I just got back from a 4 plus week USA trip in our Excella classic which included disc brake installation by Airstream at Jackson Center along with some other work (great experience which I will post later). Airstream just recently started using/suggested ( via the service guys and the Engineers) the Hayes/Lemmerz "Genesis" controller which solved my controller incompatibility issues I had with my existing Omnibrake controller on my tow vehicle which I had used with three different trailers with drum brakes for sme time, abit with different setting needed for each. The Genesis worked really well once I got it adjusted correctly on dry pavement (it was pouring rain when we were road testing near Jackson Center), and it has multiple modes that can be easily (for me anyway) set up for different trailers with magnetic (usually drum) or power hydraulic (usually disc) brake combinations. The secret is to keep a cheat sheet of the settings for each combination. It is also recommended by Acti-brake (Kodiak)for the new Active Technologies large power hydraulic controller that was part of the package for the heavy 2 axle setup.
Remember Airstream dealers do most of the brake controller installations, not the factory, and not all dealers ask the factory for advice or open the wallets to send the techs to JAckson Center for training; and things are changing a lot in this area too.
Keep on trailering....
WLJ
wlj1943 is offline   Reply With Quote
Old 11-12-2006, 04:00 PM   #13
wlj1943
wlj1943's Avatar
1995 30' Excella
Mulino , Oregon
Same for Airstream
Airstream mechanic and I followed a similar procedure for seating the linings (hot but no smoke) as was done for Pahaska, and we looked at them to verify at least 70% area contact was made, and re-bleed a couple of times to get the response time where it should be. Airstream does not allow vacuum bleading in their shop (an insurance issue I was told); we do this vacuum procedure on the race cars in our shop with good success on hard bleed jobs but it takes lots of experience and practice to do correctly. My brakes have absolutely no delay that I can feel following the installation of the new controller.
WLJ
Old 11-12-2006, 04:39 PM   #14
2airishuman
2airishuman's Avatar
Profile:
trvler
hello trvler and welcome to airstream'n
i've got a superduty with the integrated brake controller...
and 6 discs on the airstream.
i experienced a slight delay (1-2sec) in trailer braking one time on a cold morning just after hitching up and rolling down a small incline to the first stop of the day.
i think the pads/rotors/fluid were cold. the truck had been driven for a while so it was warmed up.
otherwise i've got 32,000 miles on the discs with excellent performance...
some issues...
-early factory discs systems were actibrake/kodiac;
-this is the combo most dealers use for the retro fit, as does the factory service center.
-your unit has actibrake/dexter and some folks feel the dexters are too complicated (4 piston, floating rotors?) and the kodiac is a better product.
-the actibrake brains/reservoir is different for the 2 systems. a larger one is used with the dexters and more fluid, and different software/mapping.
i know nothing about your brake controller so you really must determine compatibility issues...
contact actibrake and they should be able to help you...
it has already been mentioned but proper bedding of the pads and rotors is essential and takes time.
i spend an hour or so doing progressive slowdowns. smoked the pads, drug the tires using the manual activation and
took 10-12 high speed '70 to 30' decelerations before i felt mine were properly bedded and the controller adjusted.
these are 2 separate issues, i'm sure you realize.
to be clearer...bedding pads/rotors must be done BEFORE finalizing the brake controller adjustment
no need to bleed or mess with the brake fluid for my setup.
factory service advised me my pads were "60% gone" at about 20,000 miles so i intended to replace the pads with ceramics last week after the 31,000 mark...
on first hand inspection and compared to brand new pads i've actually still got 90%+ left and the rotors are nearly perfect....and thats with 5 trips over the rockies...
so i might get 50-60K miles from these pads...unless i get hyper2change...
back to your situation. since you are using a haha it is absolutely critical that you get the brakes sorted out...
trailer pushing tv is the one situation that we hensley users do NOT want...
ever.
keep us updated...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Online source for classic cars & more 83Excella Off Topic Forum 4 03-05-2007 10:02 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 09:26 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
Airstream Forums - Airstream Classifieds -
