Old 11-19-2014, 06:14 PM   #15
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
As I recall, the Voyageur has a small swinging weight, whereas the Prodigy is solid state.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-19-2014, 09:58 PM   #16
2007 22' International CCD
Prodigy P2 that I have can be mounted at a wide range of angles under the desk, and it self-calibrates--its all electronic inside--no weights. It seems to also compensate for going uphill and downhill because it reacts to inertia inputs--the harder you brake the TV the more power goes to the AS brakes. Its very smooth and fast. I run with a bit of boost because I tow with a Crew Cab short bed Tacoma that needs the help boost gives.
What I like about it, in combination with a ProPride hitch system is the fact that full-on panic stops are manageable. Nothing quite so much fun as getting well into the ABS on the TV because both my feet were on the brake pedal, and having the AS, with its brakes full on as well, stay in line behind me. Came to a stop will all 8 smoking a bit, and that was priceless--no contact with the fool that stopped short in front of me for NO reason....
I did want to step out and reason with him a bit, but I suspect the look on my face was enough reason for him to leave the area in a hurry. Sad, I really wanted to see if my 4-cell MagLite would bend if swung hard enough....
KE4GNK/AE
Old 11-20-2014, 06:28 AM   #17
2013 25' International
mont st hilaire , Quebec
hi finaly I install a p2
all told me its more easy to fix and have great comments on
thnk you
socool69 is offline   Reply With Quote
Old 11-20-2014, 04:42 PM   #18
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I noticed one of our trucks has a Hidden Hitch Pilot brake controller. I ain't never heard of such. Where did it come from?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Ford or Chevy OEM Brake Controllers with Elec-Hyd brake equipped Airstreams? JFScheck Tow Vehicles 30 11-10-2011 11:29 PM
Anyone Collect Antique Brake Controllers? GT1963 Brakes & Brake Controllers 6 02-23-2004 04:54 PM
Hidden Brake Controllers Dr. Harold Becker Brakes & Brake Controllers 4 07-13-2003 08:13 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
