Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-03-2006, 06:06 AM   #29
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Bill ~ I think that the GM cable kit works on 03's to the current models. I remember several threads that talk about fuses in GM trucks, they had to do with the line that charges the battery from the truck. It seems that GM left that fuse out and trailers batteries were not getting charged.
Richard
Charter Member Four Corners Unit
Old 07-03-2006, 06:53 AM   #30
BillTex
1 Rivet Short
Profile:  1989 25' Excella
By The Bay , Rhode Island
Thanx, yes as I remember there is a fuse to replace a "dummy" under the hood...
BillTex is offline   Reply With Quote
Old 07-03-2006, 09:44 AM   #31
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
The fuse in my '01 2500hd is a 40 amp that must be plugged in to power the brake circuit.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
davidz71 is online now   Reply With Quote
Old 07-03-2006, 06:51 PM   #32
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Here is a pic of the 40A fuse installation. This fuse was taped to my OEM '06 GMC 2500 pigtail and my local dealer's diesel mechanic showed me right where to put it. As you say, there was a dummy plastic insert before I put the pictured fuse into position. This is in a fusebox at the top left edge of the front quarter panel, right behind the main battery. Front is to the left. See this post.
CanoeStream is online now   Reply With Quote
Old 07-03-2006, 09:55 PM   #33
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
First thing I would do is dump that fuse and replace it with a similarly rated auto-reset circuit breaker! If that fuse blows for any reason and you need your trailer brakes.....THEY WON'T BE THERE!!!!!!!!!!!!!!!
I have great difficulty believing that GM would equip any vehicle for towing with any type of fuse in the trailer brake power circuit.
The auto-reset breaker will at least pulse the brakes if you have an over current situation. A blown fuse will do NOTHING!!!!!!!!!!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-04-2006, 03:41 PM   #34
BillTex
1 Rivet Short
Thanx Bob
Old 07-06-2006, 11:04 AM   #35
BillTex
1 Rivet Short
Hi Bob, do you know if that was the second fuse slot from the left?
I believe the first slot is blank?
Can you confirm?
New truck is due today and we leave tomorrow!
Thanx, Bill
Old 07-06-2006, 11:58 AM   #36
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Davidz71 -
I had a different experience with the fuse in my 2004 Chev Silverado 2500. It was over a year before I discovered that there was only a dummy fuse in its place. During that time, my brakes and everything worked properly - what I was missing was the 12v hot line to the trailer. This was why my trailer battery would not charge even after a long day's travel - and I found myself with absolutely no battery during our last night in the Smokies. Once I found the fuse and installed it, the only thing the fuse did was send power to the 12v hot line to the trailer.
Pat
pmclemore is offline   Reply With Quote
Old 07-06-2006, 08:13 PM   #37
Loren
Loren's Avatar
Profile:
BrakeSmart
tslanier,
I wouldn't want you to think that we are all of one mind about this issue, and I'll admit that I have never tried a Prodigy.
I have NEVER heard of anyone who has tried a BrakeSmart say that he would ever go back to anything else. That's true for me too.
I installed a BrakeSmart a couple of years ago and the trailer "disappeared". When stopping, it was like the trailer was not there. The only disadvantage I see to a BrakeSmart controller is that it is about twice as expensive as whatever controller is in second place. I think mine was about $350 or so.
I installed mine myself, but unless you are comfortable about working on your brake system you should have it done professionally. My truck has four-wheel ABS and that system still works just as it did when new. There are no problems with tapping into the brake hydraulic line as long as the system is bled properly and the fitting doesn't leak -- two easy items to check.
You will not be disappointed with a BrakeSmart controller.
Loren
1997 - 34' Classic Limited Front Kitchen.
2000 Dodge 2500 diesel with Pulliam Pull-Rite hitch.
Loren is offline   Reply With Quote
Old 07-06-2006, 09:53 PM   #38
AgZep
Profile:  2005 28' International CCD
Las Cruces , New Mexico
Another vote for the Brakesmart.
AgZep is offline   Reply With Quote
Old 07-06-2006, 11:47 PM   #39
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Stay away from the Time delay controllers like the Hoppy. If I'd known better I'd have never bought it. So much for trusting the RV dealer. The other interesting design I'll throw in the mix is the Jordan.
bhayden is offline   Reply With Quote
Old 07-07-2006, 04:25 AM   #40
BillTex
1 Rivet Short
Prodigy-set it and forget it.
Just moved mine into my new truck last night-took all of 10 minutes (maybe).
Bill
Old 07-07-2006, 01:41 PM   #41
azflycaster
Phoenix , Arizona
Images: 58
Prodigy - It stops the trailer when I stop.....
Richard
Old 09-08-2006, 10:42 AM   #42
Streamer1
Profile:  2007 25' International CCD
Arlington , Virginia
Question Trying to understand brake controller operation
I have been reading various posts with regards to brake controllers. I will probably purchase the Prodigy due to simplicity of operation, installation, etc... I also understand the brake controller's function is to coordinate the effort to stop the TV-Trailer combination in sync. What I don't truly understand is when you plug the controller into the pre-wired setup on your TV, does the controller then receive input information from the TV's onboard computer and/or braking system AND does it receive some sort of input from the 7-pin connector from the trailer which I suppose is feeding the controller some sort of sensory data which the controller utilizes to stop eventually stop both vehicles in tandem?
Streamer1 is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
