Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-22-2007, 08:01 PM   #121
Naples , Florida
Originally Posted by woodedareas
I finally got around to using my new P3. It was excellent. We drove from Illinois to Northern Wisconsin and it performed beyond my expectations. I did not use the extra feature of the Power Boost. But I am considering using it as it might offer a little extra stopping power.I wonder how many of you with the new P3 use the Power Boost feature?
I have used the boost since I got the CCD with the older Prodigy. The boost simply starts the brake current at a higher level than zero, depending which boost level you choose. I am currently using B-1 and find it very adequate when stopping the 19CCD. The boost guide found in the instructions is very accurate in helping you determine which level to chose.
Try it.......................you'll like it!
lewster
Old 07-23-2007, 10:23 AM   #122
2007 25' Safari FB SE
Lake Forest , Illinois
The instructions are very clear and suggest that I use Boost Level B-1. I was a little hessitant as I was concerned that it might provide too much stopping power, but know that I undrstand its function I will try it the next time out.
woodedareas is offline   Reply With Quote
Old 11-15-2007, 08:54 AM   #123
Bambi75th's Avatar
2007 19' Bambi
Baltimore , Maryland
New Prodigy User
I just replaced our time based (POD) controller with a Prodigy. What a great improvement! So far we have only pulled our 19' 75th Anniv. Bambi on local streets and have not yet tried the boost feature. We will be taking the Bambi to the dealer (100 + miles away) for some warranty work, so so I'll experiment some more then and will post results and impressions.
Bambi75th is offline   Reply With Quote
Old 11-15-2007, 01:15 PM   #124
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
I just installed a Prodigy in my 99 'Burb last week - very straight forward process. We had a Prodigy in the GMC van that I gave to my son, but I left it in the truck for him (figuring he and his family can use the Basecamp from time to time). The only thing that was a problem with the install was getting to the cold side of the brake switch. I got around that by tapping into that wire where it enters the cruise control module - a LOT more accessable.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 04-06-2008, 01:47 PM   #125
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Help Please?! We have just purchased a Prodigy 90185 controller which came w/4 pin plug in wires (4 colors - blue,black,red & white), which we see plugs into the back of the Prodigy unit. Problem is we have a 2001 Suburban that came w/tow pkg (heavy duty, we think). We purchased the car used & under the dash is a plug w/5 pins. Question is - do we need a different bridging plug for this to work? Thanks.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 04-06-2008, 03:38 PM   #126
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
Hi,
Most likely you will need a wiring harness, specific to the model year of your truck, to connect the controller.
Take a look here:
Tekonsha
and here:
Tekonsha Prodigy Brake Controller Install by BillaVista - Pirate4x4x.com
and here:
http://www.airforums.com/forums/f439...ler-31538.html
Hope this information is helpful.
Patrick
Airstream 65 is offline   Reply With Quote
Old 05-24-2008, 11:46 PM   #127
Jim J
Jim J's Avatar
2014 30' Flying Cloud
Red face Prodigy
I just bought my first Airstream and bought a Prodigy brake controller at the local Airstream dealer who also installed it. Except the installer forgot to hook up two wires on my 2007 Tahoe that would provide power to the controller and provide power to the brakes in the trailer - oops! That was fixed pretty quickly on the second trip back to the dealer. I noticed the Prodigy display was not lighting up when the ignition was on and that started to worry me as I made plans to pick up my 2005 25FB from a private owner in another art of the state.
On the way to pick up the trailer, I noticed my cruise control had stopped working. I wondered if it had something to do with the brake controller, so I removed the plug and the cruise returned to life.
When I got to the pickup site and plugged in to the trailer, the Prodigy display told me I did not have a ground. I checked the ground and it seemed to be OK but just to make sure I spliced in another ground to the chassis. Still no ground.
I called the Tekonsha tech support number and - an American voice answered on the second ring boosting my confidence that I was going to get somewhere.
Don't you just hate it when you call the 800 helpme line and someone from India answers and says " Hello Mr. Jeem. Thees ees Bubba, how can I help you today?" and your thinking to your self, "Bubba?" that don't sound like no Bubba!)
I described the symptoms and at first the technician was suspecting a blown controller but then he asked me to check the cable plugging in to the back of the Prodigy. I did and it had the center two wires reversed. He told me how to fix that problem and assumed I was comeptent to do it (unlike Bubba from Bombay who assumes you are a complete idiot because you do sound like a real Bubba.) Once I rewired the cable to match the wiring diagram, eveything worked OK, even my cruise control!
Turns out the cruise was not working because the controller was trying to go through the brake lights for ground and signaling the cruise that I was applying the brakes.
Once it was working I followed the set up instructions and found the braking action to be very good when using boost level 1 and set to a little higher than the 6V that was my starting point for the brake foltage adjustment.
Except for the miswired cable, everything worked fine and as advertised.
As far as the Tahoe goes, it is prewired for the brake controller but the 12 v line appears to be always on. I would prefer to have a switched 12 V line so the brake controller can be left in teh vehicle plugged in all the time without fear of running down the battery.
Jim J is offline   Reply With Quote
Old 05-25-2008, 10:16 AM   #128
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I put an inline switch on the power cable of the P-3 prodigy brake controller I put in last month. I just made a little bracket that mounts under the controller mounting bracket and puts the switch behind the controller out of sight.
Old 05-25-2008, 07:07 PM   #129
2003 25' Safari
Kissimmee , Florida
I believe the brake controller is supposed to be wired to an always hot lead. The Prodigy has circuitry to turn itself off after a while if it senses no motion - so no battery drain problems. It comes back to life immediately when you apply the brakes.
Perhaps if you accidentally leave the truck in neutral and the rig starts rolling you can jump in, hit the brakes, and have the trailer brakes work without turning the ignition on. Seems like a far-fetched need... but it's all I could think of!
Dan
dmac is offline   Reply With Quote
Old 06-09-2008, 11:58 AM   #130
strmstr69's Avatar
Auburn , Washington
As well as the above mentioned run-away scene, having your controller always hot will insure your settings will remain in the gizmo's memory. Thus no need to reset every time you go to tow.
Dan
strmstr69 is offline   Reply With Quote
Old 06-09-2008, 09:37 PM   #131
Vintage Kin
Fort Worth , Texas
Originally Posted by bhayden View Post
We have an Impulse made by Hopkins Mfg. Corp (aka Hoppy). It's a "time delay" type controller and doesn't sense inertia. In some respect I like this idea better as our tow vehicle is a little marginal and since I like to brake as slowly as possible the inertia type I think would put more strain on the TV brakes. I also wonder about long down grades where you're "riding the brakes" to maintain a constant speed. No speed change means no input to the interia sensor, right? That means you be relying heavily on the TV brakes on grades, the very situation Scott reports.
I'll have to live with it for a while. Hopefully the trailer brakes get less grabby with a little wear. Fortunately the control is easy to reach and dialing it in isn't too bad. The digital readout makes it easy to hit the right setting. A little adjustment of the brake light switch may also be in order. Right now you can depress the brake a little before the TV brakes actually engage. I looked to see if there was an adjustment on the time delay but couldn't find any info.
I also have one of these junkers. I set it at 35% for city, and 70% for highway, with the CONSTANT irritation that I will be running into a problem that require re-adjustment . . but I'm already involved in fast double-clutching my way down the gears with appropriate braking and steering inputs. That Hoppy is a liability by design, I'd need a third hand and a second set of eyes on stalks to get it right.
I was going to buy BRAKESMART when I was in Weatherford, TX having Roger Williams Airstream install my Hensley hitch, but Dave Tidmore got me intrigued by what he said he'd been testing in controllers, so I decided to wait. Even talked to one of the Dr. Performance shop guys who had pulled up behind the dealership to work on another vehicle. Wish now I'd gotten it then.
I had long admired the Jordan (still do, and have taken Andy Thomson's positive comments about it to heart) but it still ain't in production.
My trailer isn't going anywhere for a while, but, if it does, then I'll get a Prodigy or P3 for the mean time.
Old 07-04-2008, 09:24 PM   #132
Jim J
Jim J's Avatar
I just completed 1500 miles of driving on country roads, city, intersate and mountains and the Prodigy worked fine. The only problem I had was the miswired cable but after that was fixed it worked fine. We had a few emergency stops and everything went smooth and I was pleasd with the stopping distances I was able to achieve.
The unit does power itself down after 15 minutes with no activity and ignition is off so it has not put a burden on the vehicle battery
Old 07-11-2008, 04:44 PM   #133
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Originally Posted by REDNAX View Post
I also have one of these junkers. [Impulse made by Hopkins Mfg. Corp (aka Hoppy)] I set it at 35% for city, and 70% for highway, with the CONSTANT irritation that I will be running into a problem that require re-adjustment . . .
After living with the Hoppy for almost two years I'll have to concur with the assessment that these are junk. The constant need for dialing in the adjustment is a pain and I think the lever operated lever brake system they had in the Long Long Trailer would be easier to use. TRAILER BRAKES!
I think I've said it in other threads but it's worth repeating. Don't buy a Hoppy. Should have kept the old Hayes system off my parents old '72 Pontiac
bhayden is offline   Reply With Quote
Old 07-22-2008, 04:32 PM   #134
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
I'll put a shameless plug in for my Tekonsha P3 Brake controller for $75.
Airstream Trailer & Motorhome Classifieds - Tekonsha P3 Brake Controller - Powered by PhotoPost Classifieds
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 09-19-2008, 09:49 AM   #135
Sierra Papa
2007 25' International CCD
Preston , Idaho
Sounds to me like a prodigy is plug and play... any experience out there with adding the prodigy to a 2008 landcruiser? Anything about a toyota that would be different than a domestic vehicle? I am not sure but I think the tundra and the 08 landcrusier are a lot alike if there are tundra experiences out there. I need to get a controller on my new landcruiser by a week from today, and the simple plug and play sound good to me.
Sierrapapa is offline   Reply With Quote
Old 09-19-2008, 11:20 AM   #136
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Check with your Toyota dealer. I read somewhere that the 08 Landcruiser does not come with a plug for a brake controller. If that is the case you would have to tap into the wires to install one. Does the LC have a seven pin trailer connector installed?
Richard
Old 09-19-2008, 01:09 PM   #137
FFWilliston
2021 30RB Classic
Myrtle Beach , South Carolina
Absolutey, go Prodigy. It is the best I have used. Recommend the model that works when backing up. ffw
ffwilliston is offline   Reply With Quote
Old 09-16-2009, 08:29 PM   #138
The Silver Biscuit
2004 28' International CCD
If the Cruiser is like the Tundra and Sequoia, it is pre-wired for the trailer brake controls, including Prodigy. I've mounted them in both, and you just mount the controller under the steering wheel right in front of your right shin. Very happy with the prodigy.
Rosie39j is offline   Reply With Quote
Old 01-23-2010, 07:52 PM   #139
1969 21' Globetrotter
Cambridge , Massachusetts
Soon I'll be doing my first Airstream towing. I guess I'll go with Prodegy for brake control based on reading this thread but I would like to know the difference between P3 and P2 and what I should expect to pay for each. Which is recommended? also I know I will have to buy an adapter to fit the connection in my particular TV (2004 GMC Envoy). Are there are any other extra items required?
Thanks, John
JoePfznik is offline   Reply With Quote
Old 01-31-2010, 09:05 PM   #140
Vintage Kin
Fort Worth , Texas
eTrailer is a retailer with a fair amount of info, I saw them/him post on another site about the question.
My choice would, however, be a MAXBRAKE.
MaxBrake™ - Hydraulic over Electric Variable Brake Controller
Technology, here, has changed quickly. Ten years ago, it was the JORDAN 2020, then the BRAKESMART. Now, MAXBRAKE (among commercial RV tow'ers; threads read). And the factory packages keep changing, improving.
Take your time.
