Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 09-15-2006, 09:05 AM   #99
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
Ooooo! Sugarfoot, I'm glad you found this out before it resulted in no brakes on the road...or is that how you found out?
Family of Disney Fanatics
WBCCI# 4821
Old 09-16-2006, 08:50 AM   #100
5cats
just jd.
5cats's Avatar
Profile:  2007 20' Safari SE
San Diego , California
It looks like that modulite device provides power strictly for the trailer lights, and doesn't involve the braking system at all
2007 20' Safari SE/LS // 12063 // xxxx
5cats is offline   Reply With Quote
Old 10-07-2006, 05:44 PM   #101
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I installed the Prodigy in my 97 F250 today. Got in a good spot, wired up & all fine so far. Question is do you leave it plugged up all the time? No reason to unplug as it does not seem to draw any power. The leds go out after the power is off a few minutes. Just wondering to be sure though.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 10-07-2006, 05:53 PM   #102
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I leave mine in all the time. I think I would damage the mount or wires if I tried to remove it after every trip. No problems with battery drain, like you stated it times out after a few minutes.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-07-2006, 05:55 PM   #103
funchucky1
funchucky1's Avatar
Profile:  Currently Looking...
Riverhead , New York
I've had my Prodigy in place for over four years. Haven't unplugged it once. Works like a champ. Never a dead battery, either. ('course, I'll probably have one in the morning, that said).
-Chuck
funchucky1 is offline   Reply With Quote
Old 10-07-2006, 06:43 PM   #104
ALANSD
Thanks for the quick replies....I thought so but wanted to be sure. I just need to do the set up routine next to get the braking level right.
My Music Site:
Old 10-07-2006, 07:06 PM   #105
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Just an FYI I do remove mine on a regular basis. I use it in 3-4 different trucks with 6 different trailers. So far I haven't had any issues with it at all. So taking it in and out doesn't appear to affect it at all. I do use the quick release brackets. The trailers range from a 2500# single axle closed cargo trailer, dual axle dual wheeled equipment goose neck to triple axle that is rated to 28k
Aaron
WBCCI #2449 AIR #2495
Old 11-26-2006, 12:05 PM   #106
Brow324
Brow324's Avatar
Profile:  2007 27' Safari FB SE
Rowlett , Texas
Hi Folks...if my issue has already been addressed I apologize for asking,,,
but I need a fix to this problem. Just installed a new Prodigy and drove 1200 miles from Texas to NC with it: When my headlights come on, either automatically or manually, the Prodigy applies the brakes....and the display
reads voltage applied. I have to back it down to 0.0 (no voltage) to keep it
from dragging the brakes. TV is a 2001 Chevy 2500 HD. I'm using the Tekonsha supplied GM wiring harness. Any thoughts? Need to fix this by
Wednesday if possible for the return trip home. Going to call Tekonsha on Monday morning. thanks!
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 11-26-2006, 12:26 PM   #107
azflycaster
Phoenix , Arizona
Images: 60
Your brake controller should not know if the lights are on or off. The only thing that I can think of that might cause this problem is you have the wrong cable to the brake controller. They have 2 different cables depending on the year of your GM product. You should have cable #3025 (1999 to 2002). The newer cable (#3015) has the brake sense cable in a different location in the plug. You can verify the location by looking at this:
http://www.tekonsha.com/files/Produc...2020020013.pdf
Richard
Old 11-26-2006, 04:22 PM   #108
Brow324
Brow324's Avatar
Rowlett , Texas
that makes sense...I think the company I ordered it from sent me the wrong wiring harness. I will take a look at the harness plug to determine if I can move the red wire to the correct socket and call them to have the correct harness sent to me. thanks!!!!!!
'07 27 FB - H.A.
Old 11-27-2006, 01:21 PM   #109
Brow324
Brow324's Avatar
Rowlett , Texas
THANK YOU AZFLYCASTER!!!!!!
I relocated the red wire to the correct socket sleeve for my 01 TV and ran a system test...all is working properly now. Appropriate email also sent to the vendor who sold and shipped that harness to me. Hopefully they will take note of the differences between model year changes as they relate to the wiring harness and maybe prevent future customers from having a brake lockup experience on the highway when the headlights turn on.
THanks again! The sharing of your knowlege is greatly appreciated!
'07 27 FB - H.A.
Old 12-02-2006, 03:29 PM   #110
Brow324
Brow324's Avatar
Rowlett , Texas
Just a follow up after the 1200 mile trip home:
The Prodigy worked perfectly all the way. thanks again!
'07 27 FB - H.A.
Old 01-18-2007, 05:30 PM   #111
stonymo
stonymo's Avatar
Profile:  2006 31' Classic
Jefferson Co , Ohio
Just a quick question along the same topic, anyone hear of a (Hayes) genesis brake controller? If so... thoughts?
stonymo is offline   Reply With Quote
Old 03-25-2007, 10:05 AM   #112
nvestysly
nvestysly's Avatar
Profile:  1992 29' Excella
Metro , Atlanta
Hayes Genesis Being Installed By Airstream
We have our '92 Excella in Jackson Center for some upgrades - including disc brakes. Airstream currently installs the Hayes Genesis controller unless you prefer something else. I did not have a controller in mind so I deferred to Airstream. I did ask about the Prodigy since I've heard about it on this forum.
Airstream said the Prodigy will likely work fine with the disc brakes. However, there have been some complaints with Prodigy working properly with the disc brakes. Apparently there have been no complaints with Hayes Genesis working with the disc brake installation.
We'll be picking up the trailer in April. I'll give an update at that time.
Lucius
Lucius and Danielle
AIR#25 WBCCI#16771
'92 - 29' Excella
'96 - GMC C2500 Suburban
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
