Old 07-14-2015, 07:17 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Brake Controller Recommendations
What brake controller would you recommend for a 2008 Ram 2500?
Old 07-14-2015, 07:22 AM   #2
2016 30' Classic
Erie , Colorado
Prodigy P3 unless it has a built in controller. There have been other forum posts where the built in controller had issues. So if you have the built in try it other wise Prodigy.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NŘVPN
ghaynes755 is offline   Reply With Quote
Old 07-14-2015, 07:30 AM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I LOVE the P3. I do believe it's the best controller made thus far.
NavyCorpsman is offline   Reply With Quote
Old 07-14-2015, 07:33 AM   #4
Castle Rock , Colorado
P3, I have it on my 14 Jeep diesel. Works great.
kmlacroix is offline   Reply With Quote
Old 07-14-2015, 07:47 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I have been using the Tekonsha Primus IQ Trailer Brake Controller (1 to 3 Axles - Proportional) installed in our 1995 F250 to control the brakes on our 1987 Avion 34W. It installed easily in our truck because it was already wired for towing. All I had to do was find a place to mount the bracket. It fit nicely in an existing cubbyhole at about 5 o'clock in relation to the steering wheel.
Between the controller and 6 new brake assemblies, It has done a great job of helping stop this heavy trailer.
Tekonsha Primus IQ Trailer Brake Controller - 1 to 3 Axles - Proportional Tekonsha Brake Controller TK90160
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 07-14-2015, 07:48 AM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I'm very happy with my TruControl Gold
I set it for load at the start and let it do the rest.
Old 07-14-2015, 08:01 AM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I own one the very best brake controllers ever made - problem is that it is no longer made - Max Brake.
If buying new I would opt for the Direclink Brake controller. It as close as you will get to smooth, proportional braking now that Max Brake is gone.
I once had Prodigy P2 - which I wouldn't even recommend as a paper weight.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 07-14-2015, 08:12 AM   #8
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
I second the nomination for the Direclink. I switched from the Prodigy P3 and wouldn't even think of going back. Direclink is very smooth and is also excellent at slow parking lot or campground speeds--no jerking.
Edistobob is offline   Reply With Quote
Old 07-14-2015, 08:25 AM   #9
PaulnGina's Avatar
Good Ol' , USA
I would love to hear from the different posters that have a preference of one controller of another. I haven't had any problems with our Primus IQ, so all I have are positive things to say about it. If I could get some input like that, I'm sure it would help others looking for a controller. What negatives have you experienced? What do you like about the one(s) you recommend? All I know about our Primus IQ is that is seems to do a good job of stopping our trailer.
I am a firm believer in "you get what you pay for", so if there is a "better" controller than what I have, I would consider replacing it if I can justify the change/improvement.
1987 Avion 34W
Old 07-14-2015, 08:31 AM   #10
aftermath's Avatar
Spokane , Washington
I have a Prodigy and when properly set up there is no jerking. What I like about it the best is the boost function. I set mine up as per instructions and it stops smoothly without issue. When on the road in hilly terrain I will up the boost simply by hitting the button. When I get into steep downhill situations I will boost it up again. Once I failed to set it back to normal and I noticed the grabbing when in town.
I really like how easy it is to set up and use.
aftermath is offline   Reply With Quote
Old 07-14-2015, 09:21 AM   #11
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I have the P3, it's great,
Have towed with a P2, a Primus, a Factory Ford F250 controller and a controller similar to a voyager.
The P3 is much smoother and easier to adjust than any of the others I've used. I have 2 trailers and 2 tow vehicles, and have towed other trailers as well with the P3, it's easy to adjust to match the load to the tow vehicle.
I also had excellent customer service from Tekonsha, very helpful and accommodating!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 07-19-2015, 10:56 AM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
This is the one to have. The NE version so that you can someday upgrade the trailer to antilock disc brakes. See the test and review on MR TRUCK.
Old 07-19-2015, 11:24 AM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have disc brakes on my PanAm and Classic 34's.... Use the P3 on both. Couldn't be happier!
Old 07-19-2015, 02:00 PM   #14
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
I've read some and watched demos I cant see the difference between p3 and p2
KrisE MN is offline   Reply With Quote
Brake Controller and Hitch recommendations SWillard Towing, Tow Vehicles & Hitches 35 01-10-2012 04:40 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Brake Controller/ Tire Recommendations dogpilot Brakes & Brake Controllers 7 05-31-2008 09:21 PM
Hitch and brake controller recommendations for Excursion/28' Safari PWRSTRK Hitches, Couplers & Balls 15 08-17-2004 08:45 PM
Electric Brake Controller, recommendations? Diesel Pusher Brakes & Brake Controllers 22 05-26-2004 03:59 PM
