Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-17-2003, 11:39 AM   #1
Rickk48
Rickk48's Avatar
Profile:
Brake Controller Question
I have a Drawtite Activator II brake controller with red LED digital readout. Usually, without the trailer attached, all that I see in the readout when I apply the brakes is the decimal point. This morning I noticed it read "0.0" and if I apply the manual slide it runs up to "3.5" which is the usual setting for when the trailer is attached. My question is, do I have a problem? A short or something else to be concerned about?
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 03-17-2003, 01:52 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Take a look at your electrical receptacle. During our Ohio winters, salt water migrates into the socket, and green crud begins to grow shorting everything out. Clean or replace the receptacle, and that may cure your problem.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 03-17-2003, 02:19 PM   #3
Rod Pease
Profile:
I have the same controller. Is the thumb wheel adjuster on the top of the unit rolled all the way back? I do this when I am backing up to keep the brakes from activating prematurely. When I do this I get the 0.0 reading. Other than that I've never seen 0.0 on the read out. I usually have mine set @ between 2.5 and 3.5 when I am towing.
Rod Pease is offline   Reply With Quote
Old 03-17-2003, 04:30 PM   #4
Rickk48
Rickk48's Avatar
Profile:
Thnks, I'll check the electrical connections, kinda my first thought too.
The thumb wheel is adjusted correctly. The problem is that I am getting these registrations without the trailer hooked up, which has never happened before.
Rick Klein
'01 Bambi
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
Brake controller hook-up Dimick Brakes & Brake Controllers 7 05-15-2003 09:57 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 02:44 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
