Old 05-20-2008, 03:54 PM   #1
bocotim's Avatar
2008 16' International CCD
Boulder , Colorado
Images: 75
Brake Controller Not Working
Hi Folks,
I'm looking for some advice regarding a Prodigy Brake Controller. I have a 2006 Airstream Bambi that I pull with a Nissan Frontier. I am using a Prodigy brake controller and everything works as expected.
However, we recently had the same model prodigy installed on a Toyota FJ, and when we connected the Bambi trailer, the controller does not work properly. The manual brake lever on the controller works as expected, however when we use the brake foot pedal, there is no read out on the controller indicating braking. It seems as if a signal is not getting sent when the brake pedal is used.
We took the Toyota back to Camping World where the controller was installed, but they cannot find any problems when they test.
So, just wondering if anyone else has had similar issues with their brake controller? Any guesses on why the controller tests okay at Camping World, but does not work when connected to the Bambi? Again, the same model of controller works fine when connected on the Nissan to the Bambi trailer.
Thanks.
Tim
Boulder, CO
bocotim is offline   Reply With Quote
Old 05-20-2008, 04:08 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
They're not trying real hard
Originally Posted by bocotim
... It seems as if a signal is not getting sent when the brake pedal is used.
We took the Toyota back to Camping World where the controller was installed, but they cannot find any problems when they test. ...
Take the truck back. I agree with your observation.
Camping World needs to prove they wired it right. Make them prove they wired it correctly to you.
The wiring ain't rocket science; they should be able to prove with a voltmeter or light bulb that the correct wire was chosen to be wired to the Prodigy's "brake pedal" connection.
Tom
Old 05-20-2008, 04:14 PM   #3
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
If possible take your AS with you to camping world.
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 05-20-2008, 07:32 PM   #4
Elgin , Texas
Images: 164
I'd go one better than that - make them hook it to a trailer they already have there. That way they can't blame it on the Airstream.
CW sometimes acts like Airstreams were built on Mars or something.
bake315 is offline   Reply With Quote
Old 05-20-2008, 08:57 PM   #5
lsinclair's Avatar
2008 30' Classic
Pagosa Springs , Colorado
With no display on the controller, I'd say their is a connection issue between the controller wire going to the brake switch connection. Poor connections tend to be 85% of most electrical problems.
Larry & Sandy
08 Classic 30
05 GMC K2500 Duramax
Four Courners Unit
WBCCI # 2460 AIR # 17259
lsinclair is offline   Reply With Quote
Old 05-20-2008, 10:07 PM   #6
bocotim's Avatar
Boulder , Colorado
Images: 75
Thanks for the feedback folks. We will take the A/S in with us next time and see where to go from there.
Tim
Old 05-20-2008, 10:14 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You should have a different cable to the brake controller for each truck. From what I can tell from your posts in the Toyota you have power, the manual lever works, but it does not activate when you press the brake pedal. If that is true the signal from the brake switch is getting to the controller. Verify that the correct cable is installed in the Toyota, I think it should be #3040.
Richard
Old 05-26-2008, 07:59 PM   #8
bocotim's Avatar
Boulder , Colorado
Images: 75
Just to follow up on this thread - We took the FJ back to Camping World to have them check the brake controller. They said that everything tested fine with no changes. So we brought it home and hooked it back up to the camper one more time and, surprisingly, all seems to be working correctly now.
We are at a loss as to why it works now, but happy that all appears to be fixed. We will, of course, keep a close eye on it.
Tim
Boulder, CO
brake controller DOCTOR-MX Brakes & Brake Controllers 6 11-27-2006 05:34 PM
Which Brake Controller???? blrpix Brakes & Brake Controllers 32 10-21-2005 03:13 PM
Which Brake controller Chitown AirStreamers Brakes & Brake Controllers 36 08-20-2005 12:15 PM
Brake Controller (which one ) poorboycjs Brakes & Brake Controllers 3 07-25-2003 05:42 AM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
