Old 04-02-2010, 05:23 PM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
brake controller mounting
I have a 2008 silverado and I was wondering where or how some of you have mounted your prodigy controller without making holes on the dash or trim. is this possible?
thanks,
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-02-2010, 05:37 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't worry about the holes. Mount it where you and your passenger can get to it and use it as needed in an emergency. Not mounting it where it belongs the holes in the front of your truck, after the crash, will be much bigger than those you drilled at the bottom of the dash
2004 Excursion 4x4
Old 04-02-2010, 07:24 PM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Originally Posted by oooooooooooo View Post
That might make sense if you have never used a brake controller, it would be good to place it somewhere like that. But if you've towed a lot, using brake controllers a lot in a different location, it would probably be better to leave it where you are used to having it. During an emergency is not the time to be trying to remember where you have mounted the brake controller.
most controllers, though not all, work on inertia, so screwed down vs. velcro or double sided tape is probably better. thus, I'd be in almost violent agreement with Howie, since it's only two small holes in the dashboard (about #8, probably).
I had another Forum member spank me a while back about choosing a top of the dashboard location for my brake controller.... Aside from their admonition that you don't put it on top of a dashboard airbag (DUH!!!! ), the most important thing is that you can reach it and use it instantly, without having to look for it, if, God forbid, you should need it in a hurry!
Happy trails and a safe trip to you, always.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 04-02-2010, 08:36 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Generally, the thing to do is mount them a little up and to the right of your right knee, which ends up being on some ABS plastic trim piece on most trucks. So you drill two holes and use sheet metal screws. In practice it stays out of the way then unless you have a center passenger in front, in which case it's one more thing they have to dodge.
It's an out of the way place and no one will care about the holes when you sell your truck, and you probably will never take the brake controller out yourself unless you do so to put in a different one.
Old 04-02-2010, 11:31 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, long before I ever owned a trailer, I worked at new car dealerships as a mechanic. I darn near ripped my knee caps off because of some of the stupid places people mounted their brake controllers. so when I got my first trailer, I made sure that my brake controller would be in a convienient place for ease of operation and not be a hazard to my body. My Lincoln has a pocket in the dash, just to the right of center, and that seemed to be the perfect place for it. Later after much thought I moved it into my center consul. Now it is in better sight and easier to use. Note: every vehicle is different so where you mount yours may take some deep thought. Please don't mount it where some-one will get their knee caps ripped of while entering and exiting your tow vehicle.
Name:	My Picture CD 406 (Large).jpg
ID:	99309   Click image for larger version
Name:	IMG_0872 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-03-2010, 12:03 AM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Dont worry about two little holes. It will not have an effect on the book value if you ever intend to trade it. I got my F350 second hand,it had 5500 miles on it, It already had holes in the dash from a brake control and a CB radio. My Brake controller took up some of the holes.
Like some woman in a parking lot at a mall told me after she banged the hell out of my door and left a big dent,"IT ONLY A DAM OLE TRUCK." Yeah rite lady 40k $ ole truck Compared to your $90 car.
I just let it go. Wasnt werf fight wiff her. AS I said dont worry about the holes.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-04-2010, 08:23 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
On my last two vehicles - I've placed my controller to the left of my steering wheel down below and mounted on a removal panel as seen via the pictures.
If something bad is happening I can keep my "right hand" on the steering wheel and manually engage the brakes...
I've never hit the controller with my knees (or any other body parts) yet can get to it without even thinking...
Works for me...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-04-2010, 09:52 PM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I am about to tackle the same problem. I am replacing my controller and have decided that I will put the new one in a location where the manual control can be accessed by the person in the passengers seat as well as by the driver.
Ken
Old 04-04-2010, 10:31 PM   #9
Salem , Oregon
Images: 18
Ken
Hi, Yes, this is a good idea; Mine is also in an area where my wife could manually activate my trailer brakes. In my first location, it was easy to get to, but difficult to see the display while driving. Some times I would ask my wife to watch the display and give me a number reading. New location working fine.
Name:	IMG_0871 (Large).JPG
2005 Safari 25-B
Old 04-05-2010, 06:12 AM   #10
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
thanks for all the input guys. i finally decided to put it in the pocket where the ash tray went. pulled out the ash tray, pulled out the cover and saved them for later. then i put the bracket right at the edge of the trim and screwed in with s cerws provided. works great, visible and accessable to both of us if need be.
thanks again, all
Bruce
Old 04-12-2010, 10:08 AM   #11
JFScheck's Avatar
Images: 33
Sorry guy's - I don't want ANYONE touching my brake controller when I'm driving. It's just like flying a plane - there may be TWO pilots on some larger aircraft - but there is always ONE in control....
**I Love U.S.A.**
Old 04-12-2010, 11:13 AM   #12
Cos
1973 21' Globetrotter
Middletown , Rhode Island
I don't have the same tow vehicle (it is a Toyota Land Cruiser instead) but I mounted my brake controller in ash tray location. The controller is mounted on a thin plywood square which slides into the same slot as the ash tray. During the winter when I'm not towing regularly I remove the controller and slide the ash tray back in.
Cos is offline   Reply With Quote
Old 04-12-2010, 11:23 AM   #13
Ag&Au's Avatar
Yes, there are two pilots, and it would be nice if the copilot could reach the flaps or landing gear when the pilot-in-command asked for them.
Old 04-12-2010, 04:07 PM   #14
Salem , Oregon
Images: 18
Hi, chances are I will never have to have my wife hit the trailer brakes for me, but it's nice to know if the occassion was ever needed it could be done.
2005 Safari 25-B
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Brake Controller 1953 Flying Brakes & Brake Controllers 7 04-26-2007 02:17 PM
brake controller DOCTOR-MX Brakes & Brake Controllers 6 11-27-2006 05:34 PM
New Brake controller Tin Hut Brakes & Brake Controllers 4 08-23-2004 09:07 AM
brake controller JPAIRSTREAM Our Community 3 05-04-2003 08:38 AM
