Old 01-21-2011, 02:08 PM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
It's a "timer based" controller which will work OK.
The problem with timer based controllers is that they always apply the same amount of braking (gradually, over a couple of seconds). Therefore, you have to compromise between a low setting which will improve drivability at the expense of safety, and a high setting that will improve safety at the expense of drivability. Even with a compromise setting, light continuous braking, as you might use if you see a stoplight turn red while you're still 1/2 a mile away from it, is hard to do.
The accelerometer controllers guess at how hard you're trying to stop by measuring deceleration. The MaxBrake measures the pressure of the fluid in the brake lines of the tow vehicle.
Either approach will work better than the timer with the MaxBrake providing more control and smoothness particularly on release, and also faster application in emergencies.
I have driven with all three types.
Old 01-21-2011, 03:06 PM   #16
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I use the Draw Tite and like it. You got a very good deal. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-22-2011, 10:22 AM   #17
Section8's Avatar
Wellford , South Carolina
OK. So I'm gonna say it is somewhere in the "not the best but not the worst so I'll be OK" category. I am satisfied with that for now. That Maxbrake setup sounds very advanced. As suggested, if I plan on going on tour with the Avion, I will consider upgrading; it is a big trailer.
"Hope it goes well. Our Avion is a wee bit smaller...and older but we sure enjoy it.
Join us for a rally if and when your schedule permits.
Good luck,
Kevin"
I just might take you up on that. Will certainly look into it once I get settled and all my little ducks in a row. I like to see what others have done with their shiny homes and steal some good ideas.
"Quit assin' around and get in here, boy!" -- My Dad, to me as a child
"Assin' around is man's purpose in life. Everything else is just a means to that end." -- Me, as an adult
Section8 is offline   Reply With Quote
Old 01-25-2011, 07:43 AM   #18
Section8's Avatar
Update: Controller worked great
Just an update on the new controller. It worked great after I finally got it tweeked in. I will keep it for now.
Thanks for all the advice and response.
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Brake away switch GAT Brakes & Brake Controllers 6 01-18-2011 09:38 PM
2010 RAM 1500 Integrated Brake Controller Mifair Brakes & Brake Controllers 1 01-16-2011 05:07 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
Airstream Fans-Vintage 1966 AVION 24' Travel Trailer eBay Watch Airstreams on eBay 0 01-01-2011 05:00 PM
