Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-10-2004, 09:33 AM   #1
Theo
Confused & Wandering
Theo's Avatar
Profile:  1993 34' Excella
Right here, , where ever I wake up
Brake controller
I am in the market for a new brake controller - my tow truck of choice has not got one.. I have tried many different ones over the years, and would like suggestions for the best one in 'your' experience. I have just heard that there are ones that take hydraulic input, from the brake pedal. This sounds interesting.. anyone know how, and how much..
I will be picking up the trailer in the next week, so need to get the controller kind of soon..
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 01-10-2004, 09:37 AM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
This has been a wildly popular topic in the past. There is lots of great info by using the search feature:
http://www.airforums.com/forum...der=descending
Eric
Old 01-10-2004, 09:47 AM   #3
Theo
Theo's Avatar
Thank you for the link... and the tolerance for a newbie..
Theo
Old 01-10-2004, 10:12 AM   #4
JimBrownUT
Profile:
Brake Controller
Theo:
I just purchased my 99 19' Bambi in October of 2003. I had a hitch and brake controller installed by my local company owned U-Haul location. I was very pleased with the results. They seemed to know how to install the hitch and brake controler properly.
I purchased the Prodigy brake controller. They installed it with the hitch one morning. They ran all the electrical wiring in tubing giving the wire protection from wear and breakage. I don't know what I paid for the Prodigy since it was a package deal. Check out U-Haul prior to buying. For $5 they will give you a warranty for the life of the vehicle (I think you need to own the vehicle for the warranty to apply), but they will repair or replace a product if it becomes faulty or is stolen.
I am an avid do-it-your self person with goog electrical and mechanical skills. The cost of installation by U-Haul was nominal. Iwould not consider doing it myself on future trailers or trucks.
I got a couple of other quotes from my installation and the prices were about 30% higher than U-Haul.
I have pulled the Bambi about 1,000 miles since installation and like the way the hitch and brake controller work. My hauling included mountain driving and desert driving with a 40 mph cross wind. Everything seems to work great.
Jim Brown
Liberty, UT
Jim Brown
JimBrownUT is offline   Reply With Quote
Old 01-10-2004, 10:16 AM   #5
Silvertwinkie
Aluminut
Theo
We've all been there at one point or another!
Old 01-10-2004, 10:22 AM   #6
Navigator
Profile:
I'll second the U-Haul recomendation.
Been there, done that.
Dick
Navigator is offline   Reply With Quote
Old 01-10-2004, 11:18 AM   #7
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
They are good and I have them in both my trucks but both my trucks do not have Anti Lock.
If your truck has Anti Lock I would not use this style. The next closest to the performance of that style is the Jordan.
In this day and age the Jordan is conidered the best by most and the Prodigy is the next best.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 01-10-2004, 02:52 PM   #8
remcolent
Profile:  1986 32' Excella
vledder , drenthe
I think the Jordan is the safest one
even if you lose the brakes on your car the jordan still works
I have a old car with single MC I like the idee that the jordan always works
you will spend some time upside down under the dash to install
the jordan I think its worth that
remco
remcolent is offline   Reply With Quote
Old 01-10-2004, 04:47 PM   #9
Theo
Theo's Avatar
I am not too good messing with electrics, but can muddle through if it is explained really well to me somehow.
How difficult would it be for a novice such as myself to fit a controller - i got a quote from uhaul, and they will do it, for $100 bucks plus the cost of parts, which seems a little steep, as they said it takes about 40 minutes.
Theo
Old 01-11-2004, 01:37 AM   #10
remcolent
vledder , drenthe
there is a good instruction sheet with the jordan
it will be a bit more than 40 minutes if you are
on this for the first time
Remco
Old 01-11-2004, 06:43 AM   #11
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Theo,
Based on your signature line "'02 F250 Tug" the Prodigy should be plug and play. All Fords with the factory installed towing package have a connector under the dash, you may need to add a couple of relays under the hood if they have not already been installed. I have 3 Fords at my disposal, I use a single Prodigy between all of them, also have a Dodge that I use it on but that's another story try www.brakecontroller.com for pricing. The Prodigy is very easy to install, it takes longer to mount the bracket/pocket than the actual controller. I have been very happy with mine, it is used on everything from a 2500# popup with a single axle, up to a tri-axle 12,000# equipment trailer.
Aaron
Old 01-11-2004, 11:51 PM   #12
qqq
qqq's Avatar
Profile:
Does anyone know where the prodigy connects to a y2k Silverado with 6 ? towing harness
Hart
qqq is offline   Reply With Quote
Old 01-12-2004, 04:50 AM   #13
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Hart
hart
it should plug into the top right receptical on the terminal block under the dash.
it is just above where your left foot is when seated.
there is a black plastic cover over the entire panel.
also, your truck should have been supplied with a harness for this, in the glove box with a mega fuse taped to it. brown square plug on one end.
check your owner's manual.
john
you call them ferrets, i call them weasels.
Old 01-12-2004, 05:15 AM   #14
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
They quit supplying those brake controller harnesses free in 2003, I had to pay $26 for mine.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
