Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-12-2004, 07:55 AM   #15
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Originally posted by Pick
They quit supplying those brake controller harnesses free in 2003, I had to pay $26 for mine.
Shoulda bought a Ford I got one with mine, then again you can buy the one from Prodigy for something around $9 that already has the factory plug on it.
Aaron
Old 01-12-2004, 08:08 AM   #16
linc54
Profile:  Dallas , Texas
Had installed a "BrakeSmart" from Master Brake Systems about a year ago. Had a Prodigy before that. The BrakeSmart is an improvement of the first magnitude. It taps into the brake line so sense line pressure. Works with anti-lock brakes.
I tow a 34' classic limited with a 2003 Excursion. The difference cannot be overexaggerated. HIGHLY recommended.
linc54 is offline   Reply With Quote
Old 01-12-2004, 11:17 AM   #17
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I installed my first Jordan Ultima brake controller last spring. I consider it the best unit I have ever used. I think my dealer was so impressed when he did his test drive with my new Classic, he may begin to stock them.
The install was easy. I picked my up from a dealer on E-bay at a cost just over $100. Here is a link to Jordan Research's web page. http://www.jordanbrake.com/INDEX.html
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-12-2004, 11:41 AM   #18
qqq
qqq's Avatar
Profile:
John HD
The standard 6 wires harness on Y2K half ton Silverados don't have a brake control wire only the 7 wire harness have it...(that's what owner manual says)
I have the prodigy harness, but it will be useless as there is no brake wire on the truck
Hart
qqq is offline   Reply With Quote
Old 01-12-2004, 01:50 PM   #19
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
The Jordan requires no connection to the brake light line since it works off of a direct cable connection above brake pedal. That's part of what makes this controller so neat. Its not triggered by the presence of voltage but on the depression of the pedal itself. The more pressure you apply to the pedal the greater the braking power to the trailer brakes.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-12-2004, 04:44 PM   #20
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Originally posted by qqq
John HD
Hart
hart,
just use the six wire harness and spilt out the large blue wire and run it to the rear.
john
you call them ferrets, i call them weasels.
Old 01-30-2004, 09:34 AM   #21
joshua32064
joshua32064's Avatar
Profile:
I have a Prodigy brake controller and Reese hitch and have been very pleased.
joshua32064 is offline   Reply With Quote
Old 01-30-2004, 10:43 AM   #22
Porky Pig
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
I agree 100%. The BrakeSmart is fantastic ... very smooth and natural feeling.
The installation was clean and simple. Great product.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
