Old 06-07-2007, 05:09 PM   #1
kalispell , Montana
Brake controller?
I need to fix my truck so the airstream I bought last week can hook up to it and the brakes work. Which type of brake controller is reccomended? The connector on the airstream is a big round one with 7 pins and the one on my truck is snall and flat and has four. Im planning on ordering the controller maybee from ebay and wiring it all up next weekend, is it a huge project?
Robert Rahn
Kalispell, Mt.
2006 25 safari
chaunceyboy is offline   Reply With Quote
Old 06-07-2007, 06:11 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Your going to need to match up your truck to the trailer set-up. You'll need a matching socket for the truck and youl need to add the brake controller line and a positive line for trailer and a back-up light. Those three and what you already have make up the seven. Brake contollers are available at RV supplies too.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-07-2007, 06:41 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
What CM said. I've found the Prodigy to be really good.
Old 06-07-2007, 07:57 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Robert,
The small four flat connector is for trailers without brakes. This is not your case. You wil need a new wiring harness and connector plug for the rear of the TV.
One word of caution. The brake controller hot lead needs to be hot all the time and fused. Just like your brakes light on your truck.
I would suggest etrailer.com over ebay. I have ordered from them several times and had good service. Prices seems reasonable too. ebay is not always ful of bargins.
The prodigy is a good all around controller. I had one installed in my last truck. My new truck came with the Tow command already installed.
Michelle TAC MT-0
Sarah, Snowball
Old 06-07-2007, 09:18 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Robert Rahn
Kalispell, Mt.
2006 25 safari
Hi, I didn't hear what kind or size truck you have, but by telling us you have the four pin connector, tells me your truck does not have the factory tow package. You may need more additions or modifications to make a good tow vehicle.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-07-2007, 09:42 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
eTrailer is better than eBay. I trust them and you will get your order pronto.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-07-2007, 10:07 PM   #7
funchucky1's Avatar
Riverhead , New York
Consider the Tekonsha P3 also; it's a little fancier (or more helpful) with capabilities at least as good as the Prodigy.
I'm ordering mine tomorrow!
-Chuck
funchucky1 is offline   Reply With Quote
Old 06-07-2007, 10:43 PM   #8
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Robert,
Tekonsha Prodigy has been the hot seller for the last 5 years. Enertia sensor unit that is easy to install and can be located almost anywhere on the dash.
Jordan Ultima is non enertia sensor that uses a pull cable mounted on the brake pedal. It is a little bit more difficult to hook up since it is best to mount it in a straight line from brake pedal. (not a strict requirement according to the literature).
You could search brake controllers on this site and find some long threads on the relative merits of various brands.
Also, there is an expensive unit made by the folks who make weight distribution hitches.
I think I would stay with one of the two above brands. They seem to get the most favorable press and they costs $100-125 or at least they did in 2003 when I last bought one.
There are pigtails available to make most late model trucks easy to hook up under the dash.
wingfoot321 is offline   Reply With Quote
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 12:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
