Old 03-22-2013, 10:57 AM   #1
gatewaygrip's Avatar
1963 28' Ambassador
1967 26' Overlander
St. Louis , Missouri
Brake Controller
I'm having issues with my install of a P-3 brake control. When I first hook up to my AS, no problems until I mess with the manual lever or brake pedal. When I step on the brakes the AS brake lights go out. After checking functions and trying to test the brakes to see if they even work, brake control loses connection (no trailer warning).
Is this issue due to wrong wiring in the trailer or faulty brake control?
gatewaygrip is offline   Reply With Quote
Old 03-22-2013, 11:05 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Probably wiring. Unplug the P-3 and be sure all the trailer circuits work the way they should without it, and then be sure that the wires to the p-3 are properly connected - not mixed up with each other.
