Old 10-03-2010, 01:14 PM   #1
Francisco , Indiana
brake controler
We picked up our new Ram 2500 Friday. It has the factory brake controler, will it work with my electric over hydraulic brakes?
It is a 2007 Classic 30 ft. with slide out.
Hickory
hickory is offline   Reply With Quote
Old 10-03-2010, 01:26 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
What does the owners manual for the truck say about the controller and the actuators?
Bill
Hickory
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 10-03-2010, 01:46 PM   #3
_
We picked up our new Ram 2500 Friday. It has the factory brake controler, will it work with my electric over hydraulic brakes?...
the owners manual is vague in this truck in regard to e/h brakes.
there is an ONLINE tech document BURIED in the mopar stuff...
barely ONE paragraph and it took hours to find it.
that tech doc sez the ITBC will not work with e/h brakes.
________
using an AFTER market controller is tricky now,
because the dealer has to DEprogram the oem one from the onboard computer,
and REprogram the main computer (with the vin #) to accept aftermarket controller on the harness.
____________
a master tech at the local dealership told me it would work, maybe.
then i showed him the online tech item and he changed his mind...
"nope absolutely won't work"
ultimately as part of the D/3500 test drive i HOOKED up the stream...
and tried the itbc with the e/h disc brakes...
the dodge itbc ((made by continental?)) worked fine.
so the only sure way 2 know is 2 try it.
and don't forget the syn/calibration step outlined in the a/s-dexter info.
...It is a 2007 Classic 30 ft. with slide out....
another issue hickory...
the oem RECEIVER is not labeled with ANY ratings (with or without w/d)
and the owners manual simply sez it is "class 4" which is vague.
the service shop suggested it is rated to 1000/10,000 with w/d (the basic definition of class 4)
but class 4 includes receivers with greater and lesser ratings.
the HEADz UP point being...
the TONGUE and gvw rating for the 30/slide is OVER 1000/10,000.
cheers
2air'
Old 10-03-2010, 03:26 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Excellent post, 2Air. Thanks for the time spent in research, dealer questions and the rest!!!
If the OP is looking for another hitch receiver (if communicating with Ma Mopar on this question is unsatisfactory), then a look at TORKLIFT -- the king of Class V (and above the trucks rating) -- is recommended:
Truck Camper Magazine - TCM EXCLUSIVE: Torklift SuperHitch Magnum and SuperTruss Skid Wheel
Torklift's Original SuperHitch
Of course, a PULLRITE makes this question moot.
Old 10-03-2010, 04:27 PM   #5
2006 30' Classic
Milton , Florida
cheers
2air'
What is the meaning of the above reference? When I recently installed a Dexter 1600 psi E/H actuator, there was no mention of syn/calibration in the installation instructions.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-03-2010, 06:55 PM   #6
_
Originally Posted by nickmeloy View Post
What is the meaning of the above reference...
installation ≠ setup/sync/calibration
op has an 06 stream and ram, not an 07 stream and ford.
06 streams may have kodiak or dex' calipers (depending on build date) so...
the OP may still have the oem a/s/actibrake/dexter system...
since NOT all of the actuators were recalled (only type 2) ,
and IF recalled, it's not obvious if this has been done OR the actuator changed (no leak, no change)
_______
2006/07 TRAILER setup/sync/cal/adjustment steps are covered in the a/s owners manual section B.
the truck side 4 the OP is covered in his RAM manual.
_______
the answer wasn't exactly intended/written for ford or diy actuator installs, it is specific to the op.
it would appear you have a 250 ?
250/350 setup/compatibility is covered at ~pages 256-260 of the SUPERDUTY owners manual.
dexter also provides setup/calibration instructions for the e/h 1600 in the MAIN dex' manual.
cheers
2air'
Old 10-03-2010, 10:10 PM   #7
flynmike's Avatar
2005 30' Classic
Sacramento , California
Side NOTE!
I'm about to buy a 2010 Ram with the factory actuator and I've done some research on theturbodieselregister.com and learned that most folks are not too thrilled with the factory brake controller.
It's works "OK" but from what I've read my plan is to install a Maxbrake as soon as I get 500 miles and ready to tow.
I've had a Maxbrake on my 01 Dodge for a couple years and it's one of those "once you've had it you'll never go back" kind of things...it's too nice of a brake controller to give up.
I love being able to calibrate it and forget it. No matter what I plug in and go...it's always set and stays set...no changing when i'm parking or in heavy traffic or descending a grade...always perfect...I'm not affiliated with the company in any way...just a very happy customer.
For the new Dodge you'll have to go to the dealer for a reflash of your engine computer to delete the factory controller but you'll be SO happy you got a Maxbrake
Mike
'05 30' Classic rear queen with an '11 Dodge Cummins Turbo Diesel tow vehicle
Avatar is inflight refueling of an F-15 over Nevada...best job ever!
flynmike is offline   Reply With Quote
Old 10-12-2010, 06:37 AM   #8
Francisco , Indiana
New Truck
I hooked up trailer to our new truck and the brakes work great.
2011 Dodge 2500 with factory ITBC, 2006 30ft. Classic with S/O with electric over hydraulic brakes.
I set the controler on 6.5 after a little testing. The controler also shows how hard the brakes are being applied with a range of 10 thru 50. Scale might go higher but 50 is a high as I saw it go.
Had to raise the ball one hole in the drop hitch to get the trailer level. Seem to have my Reese dual cam W/D hitch adjusted about right also. I'm off to the scales this morning to see how well I did.
Hickory
2008 Suburban - Installing Brake Controller adonh Tow Vehicles 11 03-22-2012 12:00 AM
2009 Yukon 2500 Integrated brake controler evsjr Brakes & Brake Controllers 12 07-02-2009 04:06 PM
Having a little trouble hooking up the brake controler. SaabLover Brakes & Brake Controllers 1 11-04-2007 09:26 AM
Do I need a Brake Controler? bridger Brakes & Brake Controllers 15 07-11-2006 02:18 PM
