Old 02-17-2008, 05:10 PM   #1
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Brake Circuit Protection
Is there any kind of circuit protection on the normal brakes before the controller and on the break away switch circuit?
Old 02-17-2008, 05:32 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
THE F-250 has a 15A or 30A fuse upstream of the Brake controller. I am pretty sure my trailer has a breaker upstream of the break-a-way switch.
Michelle TAC MT-0
Sarah, Snowball
Old 02-17-2008, 06:03 PM   #3
Images: 59
Use a 20a circuit breaker going to the breakaway switch, unless it has three axles, then use a 30a (with larger wire)
Old 02-17-2008, 06:36 PM   #4
Aerowood's Avatar
Arvada , Colorado
Thanks I'll put the circuit breakers in. Do you know what a single axle 12" brake draws?
Old 02-17-2008, 06:39 PM   #5
Images: 59
About 3 amps per magnet.
Old 02-17-2008, 07:21 PM   #6
Keymar , Maryland
Size the breaker for the wire. Not the load. Of cource be reasonable. If you are using 10 Ga wire I would not put a 50A breaker on the line. 15-20 should sork fine if the wire is 14GA or larger.
Michelle TAC MT-0
Sarah, Snowball
Old 02-17-2008, 08:45 PM   #7
Aerowood's Avatar
Arvada , Colorado
That's what I'm trying to figure out. I have nothing right now so I need to pick the wire size. I think I'll go with 12GA then with a 15amp C/B. Thanks
Old 02-17-2008, 08:52 PM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
My hydraulic/electric system required 10 gauge, and 30 amp fuse. Probably can find out by checking with brake company.
NevadaGeo is offline   Reply With Quote
Old 02-18-2008, 05:39 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
If you plan on using a circuit breaker on your towable's brake circuit, be sure that it is the 'auto-reset' type. If you use a fuse or normal CB and the circuit fails......YOU HAVE NO BRAKES!!!!!!!!!!!!
With the auto-reset type, a fault will click the breaker off, but it will reset and click off again...allowing some current to pass thru to your brakes so you still get some stopping power. With a blown fuse YA DON'T GET NUTTIN'!!!!!!!
Old 02-18-2008, 08:53 AM   #10
Aerowood's Avatar
Arvada , Colorado
I was planning on using a circuit breaker but had not though of an auto resetting, thanks for the heads up.
Kip
Old 02-18-2008, 09:06 AM   #11
Over59's Avatar
Putnam , Connecticut
Images: 37
I have separate auto reset breaker on each axle. I will be adding in parallel a smaller amp fuse wherein a light red light comes on if it blows. That way I will know I need to check the brakes on that axle while the auto reset maintains some breaking power. I don't trust I would feel the difference in a normal stopping situation.
Over59 is offline   Reply With Quote
Old 02-18-2008, 11:18 AM   #12
HowieE's Avatar
Princeton , New Jersey
Images: 12
Very interesting to see someone else thinks as I do. I had just suggested to another posting that they install seperate fused and indicater lights on each brake location as a safty/indicater. Caught a bit of flack for it but glad you have an understanding of electronics and agree.
2004 Excursion 4x4
Old 02-20-2008, 01:51 PM   #13
1984 31' Limited
Dade City , Georgia
I am replacing the brake assemblies on my 1984 Airstream Excella. I just ordered brake assemblies that are rated for 7000 lb. Axels. Is this "overkill" and will they work? thanks!
Bill C. is offline   Reply With Quote
Old 02-20-2008, 07:23 PM   #14
1984 31' Limited
Dade City , Georgia
I am looking into re-placing the electric brake assemblies on my 1984 Airstream Excella which has three axles. The larger magnets will consume about 5 amps each x 6 wheels which equals 30 amps total in my mind. The brake circuit, I believe, has only a 20 amp fuse in the 12 volt fuse panel (or, isn't there any fuse at all in the wiring to the electric brakes?). I am thinking that this may be "overload". Are there any experts out there who may know the answer to this problem? thanks!
Walbernize UV protection Silvertwinkie Our Community 2 06-05-2011 09:40 AM
UV Protection for new A/C JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 17 03-28-2008 12:13 PM
7 pin connector protection Sky Winterizing, Storage, Carports & Covers 11 10-24-2007 12:58 PM
Blow out protection Barbara Peerenboom On The Road... 11 08-12-2004 04:03 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 02:55 PM
