Old 06-27-2010, 10:35 PM   #1
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Brake Check
If your TV has 4 wheel disc brakes, be sure to periodically check the working/non-working status of your parking brake which in most cases is a drum brake on the rear axle.
Fortunately, I didn't have a run-away vehicle because the brake wasn't holding. In fact, I had just the opposite. I had a dragging parking brake which turned out to be caused because the cable operating the mechanisms on the rear axels had rusted and locked.
In Virginia, vehicles have an annual safety inspection for brakes, lights etc. The mechanic who takes care of our vehicles missed this problem and I managed to drive over 1500 miles with this sticking issue. Finally, the problem became bad enough that the truck vibrated pretty violently as the brake grabbed and released.
SSSSsooooooooooooooo, do more checking than just the disc pads.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Check this out! cosmotini Off Topic Forum 2 09-03-2009 10:14 AM
Quick Brake Check? uniquemicro Brakes & Brake Controllers 6 01-12-2009 10:13 PM
Check this out.. enduroryda General Motorhome Topics 16 05-19-2008 08:40 PM
Check the Brake Controller Cracker Brakes & Brake Controllers 5 07-21-2005 07:47 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
