Old 06-26-2010, 04:15 PM   #1
1960 24' Tradewind
Janesville , Iowa
brake backing plate to fit a 60?
Hey folks,
Just wondering if anyone out there with a 1960 tradewind or close to, has replaced there dead man brake backing plate with a electric baking plate. I haven't found one yet that has the 5 stud 2-3.5-4 pattern and is 12". Could someone point me in the right direction.
badger is offline   Reply With Quote
Old 06-26-2010, 06:08 PM   #2
Originally Posted by badger View Post
Hey folks,
The 5 hole backing plate should also be for 12 inch electric brakes.
Old 06-27-2010, 06:44 AM   #3
1960 24' Tradewind
Janesville , Iowa
O.K. maby I'm a little confused. It looks like that round object at the bottom of the brake assembly is the magnet, which means I do have electric brakes? The assemblies seems pretty old and are covered in grease and asian lady beatle carcasses. Should I just clean them up and reassemble, or spring for all new ($120+)?
Old 06-27-2010, 07:35 AM   #4
Once grease gets on brake shoes, they are no longer good for brake service.
You can clean them until no tomorrow and the first time they get hot, from braking, the grease will again surface.
Best bet is to replace the backing plates. Many parts for 50 year old electric brakes, are no longer available.
A pair of 12 inch backing plates are available from many sources for less than $100.00.
Brake Backing Plate Question Kris. Brakes & Brake Controllers 2 11-30-2009 04:03 PM
Airstream Brake drums Backing Plates Bearings 6000# axl eBay Watch Airstreams on eBay 0 05-16-2009 02:20 PM
Airstream Brake drums Backing Plates Bearings 6000# axl eBay Watch Airstreams on eBay 0 05-14-2009 09:40 AM
Backing Plate position... HansenClan Brakes & Brake Controllers 5 07-12-2008 08:44 PM
New Backing Plate Installation Raptorrider2001 Brakes & Brake Controllers 3 06-12-2007 11:11 AM
