Old 09-09-2004, 11:44 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
brake/axle question
I was just curious about replacement brakes...I've seen people mention that the new axles come with Dexter brakes. went poking around to see what it might cost to replace mine, and from the pictures I see, it seems that all the Dexter drums only have 5 holes in them...how does one mount a 6-hole wheel to such a drum? Or am I looking at the wrong thing? What would the correct replacement brake be?
now, my brakes seem to be working fine, and the PO mentioned that he had the "brakes replaced" (whatever that means ) in recent years. I'm wondering if these brakes would fit on a new replacement axle, as mine are looking worn...or if new brakes would be required.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-09-2004, 12:10 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
I don't see the problem here chuck, just use five of the wholes and keep the other one for a spare.
Over59 is offline   Reply With Quote
Old 09-09-2004, 12:19 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Over59
I don't see the problem here chuck, just use five of the holes and keep the other one for a spare.
That would be silly. You need to get you some five-hole-to-six-hole adapter plates, and trim the aluminum skin so the tires can clear with the added width
Maybe some painted flames down the sides...
Old 09-09-2004, 12:45 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Thanks, guys. That's very helpful.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-09-2004, 03:00 PM   #5
Images: 59
I wouldn't use any kind of adapter. Just drill and tap an extra hole in the hub.
On a more serious note, you're looking at a different hub. The number of lugs depends on the rating of the axle. I think the 10" brakes have 5 bolts, and the 12" brakes are 6 bolts. Not sure if you can special order a different arrangement.
Additional info: Dexter does list an optional six bolt hub for 10" brake set, but you cannot get 12" brakes with a five bolt pattern.
Old 09-09-2004, 03:15 PM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, I'm sure I was looking at the wrong thing. the other confusing factor is that the dexters have lugs; my existing drums (KH ?) don't. they have holes. the wheels attach with lug "bolts".
so...the correct brakes are "12" x 2", is that correct? and those backing plates will match the henshen spindle?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-09-2004, 03:23 PM   #7
TomW's Avatar
1967 26' Overlander
Originally Posted by chuck
... and those backing plates will match the henshen spindle?
Be careful about that one. I was in an SOB RV store the other day & noticed some loaded, 12" backing plates on the shelf. The parts man (who happened to own an Airstream ) advised me that, while everything on the plate would work with my drums, the backing plate would not.
I posted this information in another thread on a different topic, and InlandRV eventually said something about machining some metal to make it fit would be necessary.
I'm sure there is more to this tale, but that's all I recall.
Tom
p.s. Think about the painted flames
Old 09-09-2004, 03:33 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
More useless information, Chuck:
My new axles came with Dexter 12x2" brakes. The backing plates have 5 mounting holes. These are actually 4500lb rated each.
Dexter has backing plates as well as hubs/drums available. You must make sure, however, that the spindle size and position will mate up with the new hubs,bearings.
If your drums and magnets are in good condition, then it's often best to just replace the brake shoes.
If your axles need replacing, then i would recommend complete axles. Solves a bunch of issues all at once.
Uwe
www.area63productions.com
Old 09-09-2004, 03:42 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by uwe
...Solves a bunch of issues all at once.
sure, and it costs an extra 600 bucks!!
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-09-2004, 04:28 PM   #10
Over59's Avatar
Images: 37
These guys did good by me. They found it strange to put shocks on a trailer but they remodeled my new axel to fit it and Andy blessed it after the fact. They are a Dexter dealer. Prehaps a couple new duraflex axels for Christmas.
http://www.wrighttrailers.com/ and they are no too far from you.
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Plumbing connection question clowman Fresh Water Systems 1 06-28-2004 09:19 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
