Old 11-01-2010, 06:15 PM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
brake away switch wiring?
My one month old 74 argosy 28' came with the brake away switch disconnected. Is this a normally open switch that closes when pulled? If so, am I right to assume that it is wired from the camper battery, to the switch to the positive side of the brakes?
GeocamperAS is offline   Reply With Quote
Old 11-01-2010, 06:20 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Correct.
The wire is not really run all the way to the magnets. It is connected to the wire that normally energizes the brake from your TV. That wire runs to the brake magnets.
Richard
Old 11-01-2010, 06:28 PM   #3
1974 Argosy 28
Images: 37
the yellow wire from the TV goes to the brakes. If the trailer comes unhitched and the TV comes unplugged, what would set the brakes?
Old 11-01-2010, 06:32 PM   #4
x
XXXX , XXXX
tiger one wire from the breakaway switch is connected to the yellow wire on the 7 pin connecter and the other wire is connected to the blue charge line from the battery and TV. That way if the trailer seperates from the TV the beakaway switch pin is pulled and completes the circuit from the battery to your trailer brakes and the brakes are applied.
wasagachris is offline   Reply With Quote
Old 11-01-2010, 06:45 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
This shows how the wires were connected in 75.
Richard
Old 11-01-2010, 07:15 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
Yes.
wiring colors for electric jack/ breakaway switch robertel Brakes & Brake Controllers 4 09-15-2010 01:10 PM
Pump Switch Wiring lewmad Water Heaters, Filters & Pumps 13 09-30-2009 09:27 AM
wiring light switch LarryO Lights - Interior & Exterior 0 04-30-2009 07:05 PM
Wiring Breakaway Switch The Flintstones Brakes & Brake Controllers 4 03-01-2007 11:15 AM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
