Old 01-18-2011, 03:07 PM   #1
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Brake away switch
I am going to pull my refereb for the time. It will be 30 years since it's been on the road. Just wondering if anybody has ever had to use the brake away switch. Just wonder what happened.
GAT is offline   Reply With Quote
Old 01-18-2011, 03:21 PM   #2
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I pull mine every time I'm hitching and unhitching to string the break away cable on the bumper, but be sure the umbilical is unhooked before you pull it. It tests the system, if it don't go whirr I know something isn't working right.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-18-2011, 04:33 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I just pulled mine to test the system.
Old 01-18-2011, 07:52 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Occasionally they do end up "being used" though I never have.
Many things can lead to it:
1) wrong hitch ball size
2) coupler unlatched
3) coupler out of adjustment
4) someone forgot to put in the pin that attaches the ball carrier to the receiver.
5) someone forgot to put the hairpin keeper in on said pin.
6) weld failures
In most cases where you "need to use" the breakaway your trailer is going to be toast anyway.
The breakaway reduces the chances that it will hit and injure or kill another driver.
Old 01-18-2011, 09:02 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
If its a 30 year old switch I'd pull it just to make sure it works. The last two can type switches I've dealt with had pins corroded into the housing. Yanking the cable just bent the switch over onto the tongue.
They are cheap and easy to replace.
BTW I check the pin before the first run of the season but generally leave it alone.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-18-2011, 09:06 PM   #6
If your Airstream has been parked for 30 years, without most of the weight remove from the axles, then you would be wise to check them out.
Typically, after ball park 3 years or so, the rubber rods go south. When that happens, the trailer bottoms out when it hit bumps, which in turn cause many expensive to repair damages.
The following will help you check them out yourself.
The Dura-Torque Axle
Old 01-18-2011, 09:38 PM   #7
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
I pulled the pin on mine and,even though it came out nicely, the switch did not make contact. Two things have to be checked - Does the pin pull out and does the switch send current to the brakes.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
A Switch with no apparent function Aviator Lights - Interior & Exterior 8 01-24-2011 06:18 PM
3 way switch just went kaput...replacing? MonaxLisa Lights - Interior & Exterior 24 01-20-2011 04:51 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
