Old 01-25-2009, 07:00 PM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
Brake adjustment
Just purchased an 1986 25' Sovereign and need to pull the brake drums to inspect a squelling noise. can someone give me some advise on brake adjustment?
coffeydelsol is offline   Reply With Quote
Old 01-25-2009, 07:28 PM   #2
Images: 59
I do it the same way I adjust car brakes. Tight until you can't turn the drum, then loosen until they just stop dragging.
Old 01-25-2009, 07:39 PM   #3
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
[quote=markdoane;660207]I do it the same way I adjust car brakes. Tight until you can't turn the drum, then loosen until they just stop dragging.[/quote
Ditto on the procedure....... The sound you are getting may be the adjuster laying in the drum. I had that happen to my camper. The retaining spring had rusted and broke. This allowed the adjuster to fall down, creating a squealing sound. Good luck
94Tri is offline   Reply With Quote
Brake Adjustment Shepstream Brakes & Brake Controllers 2 07-08-2007 04:52 PM
Brake adjustment GreggH Brakes & Brake Controllers 4 09-30-2006 11:15 AM
Brake adjustment ardenrj Brakes & Brake Controllers 1 08-13-2006 08:02 PM
Help on Brake Adjustment - Out of Travel khollister Brakes & Brake Controllers 3 06-05-2005 03:18 PM
Brake adjustment... drboyd Brakes & Brake Controllers 7 04-07-2004 05:56 AM
