Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 09-26-2006, 08:49 AM   #1
GreggH
GreggH's Avatar
Profile:  2005 31' Classic
Castalain Springs , Tennessee
Brake adjustment
Repacked wheel bearings yesterday on '05 31' Classic with less then 10,000 miles. When adjusting brakes I couldn't detect any difference in wheel spin wether adjustment was full tight or full loose. Is this adjustment so fine it's hard to detect. Plenty of pad on brakes.
GreggH
GreggH is offline   Reply With Quote
Old 09-26-2006, 09:00 AM   #2
jimmickle
jimmickle's Avatar
Profile:  Marion , Iowa
You should be able to lock up the wheel with brake adjustment. Take a look, with the drum off to see if you are really making an adjustment. When you get to full tight, the wheel won't turn. It often takes quite a few clicks to do the adjustment.
jimmickle is offline   Reply With Quote
Old 09-27-2006, 04:38 PM   #3
GreggH
GreggH's Avatar
Thanks Jim
Jim,
Thanks for the response. I tried again and did feel a difference. It did take quite a few clicks to tighten to get heavy drag. I had it at complete loose but guess I didn't go far enough for tightening. I was doing it with a screwdriver so some of my attempts was just making noise and not actually turning the adjuster. Guess I should invest in an adjusting tool.
GreggH
Old 09-28-2006, 01:12 PM   #4
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Originally Posted by GreggH
Jim,
GreggH
Yeah, an adjusting tool will make it a lot easier. Should be under $10 if you get the cheap one, look in the "bargain bin" at NAPA or Kragen. Don't bother getting the "Snap-on" or similar quality, for what you're doing the cheap ones work just fine.
Dave
Fyrzowt is offline   Reply With Quote
Old 09-30-2006, 12:15 PM   #5
SafeHarbor
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Speaking of the bargain bin at NAPA - I picked up a brake adjusting caliper tool that measures the inside diameter of the drum and the outside diameter of the brake drums. It should be make reassembly and adjustment much faster next time I have the brakes apart, and it was only like $33.
I'll also get a chance to use it within the next couple of weeks. I have four wheel cylinders to rebuild on a 1953 Pontiac.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 09:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 07:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 06:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
