Old 07-14-2013, 05:20 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Red face Brake adjustment
What is the proper method of adjusting drum brake pads. I've been jacking the wheel up until free, tightening the star wheel until full brakes and the wheel will not move, then loosening it 3-4 clicks until the wheel turns free. Is this correct?
steveirving is offline   Reply With Quote
Old 07-14-2013, 05:42 PM   #2
1971 31' Sovereign
fort myers , Florida
Sand the brake pads....220 grit is fine. LIGHTLY sand the drum using the same grit in a round motion.The method you mentioned is sound,but you do not need to get it too tight,initially.
swampthang7 is offline   Reply With Quote
Old 07-14-2013, 05:47 PM   #3
1959 24' Tradewind
Quantico , Virginia
Images: 11
What is the sanding for?
Old 07-14-2013, 05:57 PM   #4
1971 31' Sovereign
Have you ever installed a set of brake pads? If you have installed brand new ones,they come already slightly roughed...we always ground the edges on a grinding wheel to prevent brake "whistling". On old brake pads,the sanding is to knock off the "glazing" buildup from the pad to drum heat effect.
