Originally Posted by WK57ABF
Dave,
There is only one fuse on the brake controller and that is on the black feed to the controller which is uaually a 20 or 30 amp circuit breaker.
Check that the blue wire from the brake controller, 14 gauge (20 amp) for a single axle, goes straight to the brakes with no other connections or fuse in that line.
Don't know if you have changed the trailer end 7 blade US plug for a UK round pin plug but the wiring should be :
left turn - red
right turn - brown
ground - white
charge wire - black
running lights - green
brakes - blue
Now the most important part of the US to UK conversion - a separate wire will have to be run from the socket (trailer end) to the stop lights.
In our trailer rear light cluster, we disconnected the centre back-up light (clear lens) and fitted an amber lens and used that llight for turn signals. The other two red lenses were used for running and stop lights.
I suspect that your electrician is not familiar with the US two bulb system and in converting to our 3 bulb system has in some way used the blue brake wire to operate bulbs.
I know how to convert to UK wiring but find it difficult to put down on paper!!!
Incidentally, is your ex-electrician/light convertion guy the infamous Mr. R...., who is now wanted by the police?
John in the UK
John,
A bit of progress this weekend
The wiring you stated above is spot on and the yellow wire (not mentioned above) is used as the brake light, so brake controller and brake lights are on two different circuits on the caravan. The current draw on the brake controller wire was about 6 amps, which for a single axle is okay. When I connected the battery across white and black it blew the fuse in my multimeter, but this wire wasn't connected with the previous wiring?
Anyway, this leads me to believe it is not the cars wiring, so am calling a mobile auto electrician tomorrow!
More to come.
Dave
