Old 07-08-2008, 08:44 AM   #1
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Backing Plates
Well I finally installed my new backing plates. I had some fun loosening up the shoes so I could remove the drums. Whoever the bimbo was that did the last brake job is not on my good guy list. See how the star wheel adjuster is NO where near the oblong hole in the backing plate! Makes for a pita time to adjust brakes. WHY not just do it right the first time??
The 2 pics are with the modified adjustment tool and the how it should be look.
Speaking of doing it right-
I got my backing plates from Inland RV out here in Ca. Yea, they're in the southern part of the state I know.
I called and spoke with Gregg, he was very helpful and to the point. Got the parts quickly and installed them without a problem. I liked the part that all the bolts to attach to the axle were included.
I like to use vendors here on the forum, my experience with Inland has been good each time I've used them. Just passing it on.
Name:	86 Excella 181.jpg
ID:	63335   Click image for larger version
Name:	86 Excella 182.jpg
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 07-08-2008, 09:17 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Looks like they where installed bass ackwards.
Old 07-08-2008, 12:15 PM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Whow Doorgunner
What Boozo did that? Some people should NEVER be aloud around any type of machinery. Glad it all came together for ya.
Roger
Mikethefixit is offline   Reply With Quote
Old 07-08-2008, 06:03 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Tim, I hope you weren't wrestling with the backing plates in this heat. otta be 110* in the vinyard!
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 07-12-2008, 06:10 PM   #5
HansenClan's Avatar
1965 26' Overlander
Encinitas , California
Images: 22
Hey Doorgunner (or anyone),
When you installed the backing plate, where did the magnet end up? The reason I'm asking, I just got new axles, backing plates, drums, wheels & tires from Inland, and, the magnet does not sit bottom dead center. It is a little off to the left, the torsion arm is going to swing up a bit and that might help in its position. I am just wondering if the brake pads need to be facing front & rear or is a slight (one inch) rotation ok?
HansenClan is offline   Reply With Quote
Old 07-12-2008, 06:14 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For the magnet, if you look at the mounting arm for it, the lever should be in the front part of the mechanism, they are different left and right.
Many brake shoes have different lengths for front and rear shoes. The primary (larger friction surface) shoe goes on the rear.
Old 07-24-2008, 08:35 AM   #7
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
What Terry said!!
There are 5 bolts that hold the backing plate to the axle- impossible to mount them cocked. There is a right and left side. The backing plates I got from Inland had sticky labels on them indicating right or left side. musta known who he was sending them too.
So I tried out the new brakes on I 80 Donner Pass. I'm extremely pleased with the performance, new stuff really makes a difference.
Now I'm installing a Hensley TruControl in the burb- I'll report on that in the other thread about that controller. I'm getting before and after amp/volt readings.
www.popasmoke.com
YETI ( 65 Quart )
Best License plates... bobfowler On The Road... 5 08-15-2007 08:44 AM
Backing up, how far? LI Pets Towing, Tow Vehicles & Hitches 11 02-14-2007 05:30 AM
License Plates jcanavera Title, VIN & Registration 37 02-22-2006 08:19 PM
Backing with a Hensley Steve Heywood Hitches, Couplers & Balls 26 08-23-2005 10:30 PM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
