Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-14-2016, 08:32 PM   #1
copycat carl's Avatar
1957 22' Flying Cloud
1963 28' Ambassador
Gadsden , Alabama
Backing plate assembly for 57 Flying Cloud
Can anyone tell me where to buy the complete backing plate brake assembly for my 57 Flying Cloud. It has the original axels and I would like to up date the electric brakes on it.
copycat carl is offline   Reply With Quote
Old 03-14-2016, 09:42 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Any place that has trailer parts should be able to fix you up. I would take my old one with you just to make sure. Don't forget to get new mounting bolts for the plate and new wheel seals. I would also get new bearings if it was mine.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 03-14-2016, 10:05 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Take the old drum and bearings with you also. The new backing plates may not fit in an old drum. If the backing plates fit the old drum you can also get new bearings, if not you will know the spindle size for new bearings.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Backing plate replacement astrocaver Brakes & Brake Controllers 1 08-07-2013 05:43 PM
brake backing plate to fit a 60? whatsherface Brakes & Brake Controllers 3 06-27-2010 07:35 AM
Brake Backing Plate Question Kris. Brakes & Brake Controllers 2 11-30-2009 04:03 PM
Backing Plate position... HansenClan Brakes & Brake Controllers 5 07-12-2008 08:44 PM
New Backing Plate Installation Raptorrider2001 Brakes & Brake Controllers 3 06-12-2007 11:11 AM
