Old 10-21-2008, 05:34 AM   #1
1975 Argosy 22
Charlottesville , Virginia
Argosy Basic Brake Question
Hi All,
I have a 75 Argosy 22' with dual axels. My question is this is:
I know I have no break away switch but when my trailer is disconnected from my truck (electrically) do the brakes automatically kick in? I would think that this would be a good design where the brakes require truck hookup in order to release.
Is this how is works?
uniquemicro is offline   Reply With Quote
Old 10-21-2008, 06:00 AM   #2
Silverhobby's Avatar
Greeeneville , Tennessee
Sorry, but this is not how it works. The break-away device is a safety mechanism to apply the brakes to the trailer if it were to break loose from the tow vehicle while it is being towed. It is activated with the battery power from the trailer (battery must be in place). This would effectively stop the trailer from careening out of control, if it were to seperate from the tow vehicle.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-21-2008, 06:00 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by uniquemicro View Post
Hi All,
I know I have no break away switch but when my trailer is disconnected from my truck (electrically) do the brakes automatically kick in???
No, the brakes have magnets in the backing plates. When the magnets are energized from a signal from your brake controller (mounted in the cab of your tow vehicle) an electrical current is sent to the magnets, energizing them. The magnets, in turn, "grab" onto a mechanical mechanism and, along with rotation of the wheels, cause the trailer brake shoes to expand into the brake hub, which stops the trailer.
Since the magnets are really electro-magnetic, and draw a fairly large amperage, leaving the magnets "activated" for more than just a couple of minutes could cause the internal windings of the electro-magnets to burn out, thus leaving the entire brake assembly useless - not a good thing.
A couple of years back Dexter was offering a brake assembly that had an attached mechanical parking brake. It worked much like an automobile parking brake in that there was a mechanical lever which was hand activated, locking the brakes in the "set" position.
If interested, you could do a thorough search through the Dexter website and investigate if this option is still offered.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 10-21-2008, 07:57 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Airstream Has put hand brakes on trailers that can be set to park or controlled manually ,but I think the ones I saw at the factory were for export only.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Some Basic Radiant Heating Questions BrockLives Water Heaters, Filters & Pumps 9 03-21-2008 12:03 PM
brake question PLEASE HELP airstreamer Brakes & Brake Controllers 11 05-30-2007 04:38 PM
basic instinct gleebin General Motorhome Topics 10 04-20-2007 10:34 AM
Basic LED questions Boondocker Lights - Interior & Exterior 17 04-12-2007 09:25 PM
Basic Brake information David Hall Brakes & Brake Controllers 18 03-04-2004 06:23 PM
