Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-16-2007, 08:43 PM   #1
jbond
jbond's Avatar
Profile:  Shalimar , Florida
Images: 13
Anyone know how this worked?
A 63 Overlander I bought had this Stromberg Hydraulic Brake on the tonque.
It has a master cylinder on the back and had a hydraulic line running to the first axle. The second axle has electrical wiring running to it. The unit was rusty and the lever wouldn't move til I cleaned it up.
The lever's function on the "Brake" seems to me to be a parking brake/ break away.
Also I see in late 50's pricelist there was an option for a $10 "hydraulic brake".
Is this that option and was this used just as a parking/breakaway brake?
Or was this also plumbed into the TV's hydraulic brake lines also?
Herb
Wally# 1861
Prez VAC
63 Globetrotter Patty 62 Overlander Doc
63 Suburban Andy 63 Overlander Tex
jbond is offline   Reply With Quote
Old 01-16-2007, 11:05 PM   #2
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
My 63 did not have one but it does look like some kind of parking/breakaway brake. Looks like the break away cable could be attached thourough the loop. If it did breakaway though, I do not see how the brake would continue to be applied. Looks like you would also lose half of your braking capacity with only two wheels electrified. I think I would replace the two hydrallic backing plates and relpace them with electrics for $50 each and go with a regular electric breakaway switch.
Old 01-17-2007, 07:13 AM   #3
boatdoc
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Hi jbond; This set up did not have a electric breakaway system. A hydraulic
cylinder with a piston was used as breakaway feature. It could have been used as parking brake as well, however after being applied for a long period of time, the lining would freeze onto the drum. That idea was abandoned in a short time. This system was never tapped into tow vehicle. I recommend that you upgrade it to electric brakes with a breakaway switch, and a trailer mounted battery. Thanks "boatdoc"
boatdoc is offline   Reply With Quote
Old 01-17-2007, 07:30 AM   #4
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
That sure cleaned up nicely but as the others have said, I would upgrade to electric brakes on both axles and an electric breakaway switch. Maybe this cleaned up part can go in a museum because its probably the cleanest one in history.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 01-17-2007, 07:45 AM   #5
jbond
jbond's Avatar
Images: 13
Thanks! I planned on replacing it. Just curious on how this thing was suposed to be used. BTW there's a big spring inside the cylinder that would apply pressure to the master cylinder if the break away loop was tripped.
Herb
Wally# 1861
Prez VAC
Old 01-17-2007, 12:09 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
A cylinder with a long hose was tied into the hydraulic brake line at the rear of the tow vehicle.
That "slave" cylinder was held in place on the master cylinder, which was mounted on the front of the trailer. Airstream back then had hydraulic brakes and sometimes one axle was electric and the other was hydraulic.
That system was outlawed in the mid 60's. The slave cylinder would displace more brake fluid that the new tow vehicle systems contained.
It does make a nice "collectors" item, but it's useless on your trailer.
But, during it's day, it was not too bad.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-17-2007, 06:24 PM   #7
axleman
Commercial Vendor
Profile:  Currently Looking...
Somewhere , Indiana
Wow!
That was some pretty cool technology for its day!
I liked it so much that I saved several from units that I installed new axles on, for various customers, when I was the Axleman.
You sure did a bang up job of cleaning it up – I’m suspecting that you bead blasted it – by the appearance.
Neat post,
Henry
axleman is offline   Reply With Quote
Old 01-17-2007, 08:14 PM   #8
jbond
jbond's Avatar
Images: 13
Yep bead blasting works great.
Herb
Wally# 1861
Prez VAC
Old 01-20-2007, 06:41 PM   #9
Phil and/or Sue
Phil and/or Sue's Avatar
Profile:  1983 31' Excella
1973 31' Sovereign
Ellijay , Georgia
Images: 68
Bead Blasting Needed...
Howdy, Herb. Nice looking device! But not as shiny as your trailer.
How do I find bead blasting shops? For the taillight castings on our '73 31' Sovereign, beadblasting was suggested as a way to restore the finish. Maybe I can send them to someone?
Thanks for sharing.
Phil and/or Sue (with Gus, Penny and Roger)
(Buffett RIP 9/15/08)
1983 31' Sovereign
1973 31' Sovereign (project)
'01 Dodge Ram 2500 Quad LWB 2x4 6sp
Cummins Turbo Diesel
AIR 1753
Phil and/or Sue is offline   Reply With Quote
Old 01-24-2007, 08:33 PM   #10
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Auto restoration shops or auto machine shop will have a bead blaster. Can be glass beads, sand, walnut shells or a variety of other things that are used in a blaster. BTW, I do not recommend sand.
>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 01-24-2007, 09:22 PM   #11
Phil and/or Sue
1973 31' Sovereign
Ellijay , Georgia
Images: 68
>>>>>>>>>>>>>Action
Sand? Isn't that what they have in the dry-heat desert in Arizona?
I agree: no sand blasting, since it potentially wears metal away. Thanks for your ideas regarding auto-restoration or machine shops. I'll check around here locally.
1983 31' Sovereign
AIR 1753
Old 01-30-2007, 05:29 PM   #12
Action
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
Actually not much sand in AZ. The ground is mostly rock and hard pack soil called caliche. AZ Master Gardener Manual: Caliche Actually about as hard as concrete.
I wish we had sand.
>>>>>>>>>>>>>>>>>>>>>>>>>Action
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 05:24 PM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-17-2005 12:31 AM
Report: Southern Shine worked! rluhr Cleaning, Stripping & Polishing 135 09-07-2004 09:29 AM
A couple of things that worked Chuck General Repair Forum 1 06-09-2004 02:12 PM
New shocks when? Dbraw Axles 19 02-13-2003 11:01 PM
