Old 01-20-2008, 02:08 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
An interesting question
I put new axles on my 34 about 20,000 miles ago. Just arrived in Fl and had no brakes for the last couple hundred miles. Checked the controller for voltage and current output, checked the adjustment of the brakes, checked the magnets. All checked out OK. Pulled the drums off to find excessive brake dust. Cleaned the drums and shoes with brake cleaner and think are better now.
My question. Has anyone had problems with brake dust reducing or canceling the braking power? Are they using something new in the shoes that produces this dust?
2004 Excursion 4x4
Old 01-20-2008, 04:55 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
New axels?????
No to your question.
Then.....WHY would you have to replace the axels on a 91 Airstream.
Old 01-20-2008, 05:14 PM   #3
All torsion axles must be exercised, periodically.
If not, they will settle and/or develop solidified rubber rods.
To avoid the problem, if the trailer will be in storage for an extended period of time, then simply remove most of the weight from the axles, by putting the trailer on jack stands.
We have dealers that have replaced many axles on 2000 and newer trailers.
Old 01-20-2008, 05:17 PM   #4
Sounds like the trailer brakes have been dragging to some degree.
Another reason to do a major brake, every 10,000 or once a year.
Old 01-21-2008, 09:21 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Since asbestoes were removed from brake lining some time ago, it seems brake lining makers continuely play with the compositions to get the best of no squeaks, long lasting wear life and acceptable performance out of linings. It's not easy.
>>>>>>>>>>>>Action
Old 02-12-2008, 07:54 PM   #6
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
The dust is probably a symptom. Drum brakes when overheated will fade to useless on a trailer same as a car. Question is why it happened, hardware weak in the drum, controller adjustment, or sometimes a toe on the pedal. If severely overheated check the brake shoe surface for " glazing", shiny as glass and just as slick. If no cracks in the lining usually a gentle buffing with med sand paper will restore to acceptable.
putback is offline   Reply With Quote
Interesting Article lewster General Interior Topics 9 07-21-2007 08:42 AM
Looks Interesting lock-guy Member Introductions 4 07-10-2007 09:50 PM
Interesting till Airstream "In the News" 3 08-05-2004 04:38 PM
Interesting Bambi Pahaska Our Community 6 07-31-2003 06:28 AM
