Old 08-09-2010, 01:38 PM   #43
DnS
DnS
DnS's Avatar
2008 30' Classic
Crosby , Texas
Does anybody know what they are replacing them with?
Dave & Sheila
2008 30' FB K Classic Limited (R-House)
2007 Dodge Diesel 2500
AIR #35797
DnS is offline   Reply With Quote
Old 08-09-2010, 02:30 PM   #44
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Now they tell me
Well, the brake failure was not anything new to me. Read this thread.
http://www.airforums.com/forums/f439...own-55328.html
I've made contact with Ewald's in Milwaukee to get the ball rolling as I want a refund of over a grand for the expense of replacing the Actibake that failed multiple times for me. I had it at the factory twice with their response being it was the brake controller doing it. It still did it after I put on a new P3. I replaced Actibrake with a Dextler unit.
Would this be a good time to use the phrase "I told you so".
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 08-09-2010, 03:03 PM   #45
2007 25' Classic
Hydes
I had both of these units fail. Version one failed the day I brought my 07 Classic home. Called the dealer , Actibrake and Airstream the same day. Actibrake overnighted version two and I installed it with instructions by phone. Version two failed but not before frying my Ford in dash brake controller at a cost of $800.00. Just spent $1500.00 for brake work on my F350. I'm pretty easy on brakes but the dealer says wear was premature for the mileage. I did tow the Airstream from N.C. to the dealer in N.J witn a failed actuator so no brakes .Colonial installed a Dexter actuator .
Originally Posted by 2airishuman View Post
i have read reports of FAILED UNITS from both generations of actib' stuff...
but for those who wanna know which is which...
this is version ONE
Attachment 108398
this is version TWO
Attachment 108399
version TWO is LARGER that ONE, and has a bigger fluid reservoir...
but ONE has the brains above the fluid reservoir.
cheers
2air'
craftsman is offline   Reply With Quote
Old 08-10-2010, 07:02 PM   #46
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Can I ask very basic questions?
We have version 2 actuator in our 2008 classic and AS confirmed by phone today that it's part of the recall. They recommended we drive to the Camping World in Oakwood, GA (175 miles away) for inspection.
I've been following this thread, and need to ask some very basic questions: How do you know short of having no brakes while you are driving that the unit has failed? Someone said it failed while parked at their house. How did you know that? My trailer is sitting in an enclosed shed plugged into shore power. Absent something smoking or blowing up I don't think I would know if this thing was broken.
Can someone explain this part a little more? Do I need to be scared to death to tow this trailer 175 miles? Will I get any warning?
Sorry to be so ignorant, but I promise I can be taught!
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 08-10-2010, 07:20 PM   #47
_
this is by NO MEANS an experience opinion, so don't bank it....
but, i don't think there is ONE narrow set of clues to the failure...
short of smoke or hydraulic fluid dripping.
and apparently the actuator can display failure in one of 2 ways...
1. no brakes (when the tv brakes are in use) or...
2. FULL ON brakes without using the tv brakes...
#1 is less of an IMMEDIATE split second danger since MOST tv that are adequately equipped can slow the trailer down.
an experienced driver will quickly realize the trailer brakes are NOT working (with the longer/heavier streams)...
and slow down, then drive accordingly and directly somewhere for help.
#2 is more of a concern (in my view) because FULL sudden braking by the trailer when not expected, could lead to tires skidding...
and other sphincter activating surprises.
clearly anyone with INTERMITTENT brake function should pay attention to the signals.
((see questions and answers posted in blue in my earlier posts and #20,21,27,28 ))
and if PULLING the breakaway pin doesn't activate the pump 'normally' that's a sign to be aware of during hookups.
i am guessing the failure rate is SMALL but the potential is real.
and they've now identified WHY this MIGHT happen.
a reasonably mechanical owner could LOOK at the online schematics for the BOX and figure out HOW to look for leaks...
but that's not a substitute for a careful inspection.
of course is THAT (a careful inspection) possible at CW?...
i personally would NOT got there, but instead head to AoA in searcy, or st louie, or j/c.
cheers
2air'
Old 08-10-2010, 08:08 PM   #48
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The operation of both of these units was affected by air locks in the hydraulic system, earth connections, transient currents from DC equipment, the proximity of AC cables and incompatability with some brake controllers.
(Thanks for this, clarifies the history)
Old 08-11-2010, 07:10 AM   #49
kfrere's Avatar
2008 31' Classic
service facility location
We have to travel next week from Knoxville, TN to Chicago. Route is N on I-75, then I-64W, then I-65N. Might as well drop the AS off along the way if anyone can recommend a shop along that route to be trusted with this actuator work. Have emailed AS the same question, but, it's Wednesday and I need to get working on an appointment.
Kelly & Matt
WBCCI - #4335
Old 08-11-2010, 08:01 AM   #50
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Inspection Procedure
Hopefully this will explain the inspection procedure.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-11-2010, 08:19 AM   #51
_
excellent!
exactly what we needed to see.
thanks for posting.
cheer
2air'
Old 08-12-2010, 10:10 AM   #52
GCinSC2's Avatar
The Test is Complete
I just got the word, my actuator passed the inspection test performed at an authorized AS facility.
I also just asked my dealer to quote on a replacement actuator. I'm not comfortable about the idea that it is not leaking now so it's OK to put back on the road. If it is a known potential problem that has been identified, well, I don't like that risk.
This job is well within my talents and I'm sure I could try to beat the dealer price on a new actuator, but my expereince with asking someone else to install parts that I purchased and brought to them is the begining of a recipie for trouble. When I take my wife out to dinner, we don't hand the steaks to the waiter and ask the chef to cook them for us.
If I don't like the deal, then it comes home and I start on it with my plans.
S/OS #001
Old 08-12-2010, 10:37 AM   #53
ScottW's Avatar
Hernando , Mississippi
kfrere,
My unit failed while parked at home. It failed in the "ON" mode, ie, the pump was running - engaging the brakes. If I'd been on the road, the brakes would probably have locked up, just like pulling the breakaway pin. You can hear the pump run.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 08-12-2010, 10:54 AM   #54
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Believe someone asked earlier about trailers upgraded to disc brakes by Airstream and whether they would get the recall notice. At least in my case the answer is yes - had disc brakes installed on my 2007 20' Safari by Airstream and yesterday when I got my monthly mail it included the recall notice. I no longer have the trailer - was traded in at Colonial. Hopefully they've notified the new owner of the potential problem.
Al - K4GLU is offline   Reply With Quote
Old 08-12-2010, 03:32 PM   #55
2006 30' Classic
Milton , Florida
I am confused by the wording in the recall. Is the recall on a "controller", or is it on the "actuator"? Our 30 ft. 2006 classic has the ActiBrake actuator, and it just failed this week.
F. A. Meloy
08/12/2010
nickmeloy is offline   Reply With Quote
Old 08-12-2010, 04:42 PM   #56
_
Originally Posted by nickmeloy View Post
I am confused by the wording in the recall...
yeah they appear to be using these 2 words interchangeably...
BUT if u scan the thread it's clearly the gizmo mounted on the TONGUE that looks like a GRAY BOX.
that's the actuator and reservoir and circuit board all in one unit...
_____________
cheers
2air'
What happened to 'Airstream Classics Inc.'? cclarkego General Interior Topics 7 08-06-2009 09:17 PM
Airstream recall---new! NHTSA No 09V-159 Silvertwinkie Airstream Trailer Forums 24 06-03-2009 10:37 PM
Recall info for those towing with 2005/06 F150 Silvertwinkie Tow Vehicles 1 05-14-2008 11:26 AM
2001 Chevy recall in 2005 Question sovereignrwe Off Topic Forum 1 04-18-2006 09:12 AM
