10-13-2015, 08:48 AM
Spring
Advantage/Disadvantage
Our trailer is needing new brakes. Since the trailer also has the original axles, we thought it is also the time to have them changed.
Before we order the whole assembly. We would like to know of any advantage/disadvantage of the 10" versus the 12" brakes for our 31 footer.
10-13-2015, 09:13 AM
1973 21' Globetrotter
Houston
There are no disadvantages to a 12" brake. Where are you getting your axles from?
good luck!
10-13-2015, 11:18 AM
1972 31' Sovereign
Lexington
No drawbacks to 12" brakes. We replaced the original axels and 10" brakes with new axels and 12" brakes. Only thing to be aware of is that you'll need to jack the trailer up high enough for the 12" brakes to slide under the frame if you're doing the work yourself. We learned that the hard way, but then, our trailer sat on blocks for a few years after we took the old axels off before getting the new axels.
10-13-2015, 01:06 PM
Spring
good luck!
Thanks for the information.
We haven't quite decided on who to get them from.
10-13-2015, 01:11 PM
Spring
Thank you very much for the information. We will make sure to block it up higher
10-13-2015, 02:39 PM
2013 31' Classic
billings
, Montana
Get the 12" brakes,bigger is better....
10-13-2015, 03:47 PM
1976 27' Overlander
Missoula
, Montana
Originally Posted by Starstream
...We haven't quite decided on who to get them from.
If you choose to get Dexter and are near a dealer (and have the time) you can get them without a shipping charge. When we got ours, it took 6 weeks but the axles came to the dealer included with their regular shipment. Something to think about... if you are near a dealer. Good luck.
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
10-14-2015, 09:05 PM
Spring
[QUOTE=OilnH2o;1696566[I]].......If you choose to get Dexter and are near a dealer.........[/[/I]QUOTE]
If we go with ordering from a local Dexter place. Will they put on the part for the shocks? Or did you have to find someone to weld the part on?
When you put yours on, was it drop the old and put the new one up? Did you have to make any modifications to the new axle or to the AS running gear?
10-14-2015, 09:07 PM
Spring
Originally Posted by [B
Belegedhel[/B];1696404]There are no disadvantages to a 12" brake. Where are you getting your axles from?
good luck!
Did you get your axles locally?
10-15-2015, 02:02 PM
Houston
No, I ordered mine through Colin Hyde. I had to have it shipped to a place with loading dock, etc., and there is a shipping terminal just of the north 610 loop that served the purpose at no extra charge, so that is where I had it dropped off/held so that I could come pick it up.
Reason I asked where you were getting yours from, is that I was just curious if you had found a local supplier. Ordering through Colin was pretty painless, as about the only information you need to have is the year and model of your trailer. Anyway ordering that way, the 12" drums are pretty much standard.
good luck!
10-15-2015, 02:22 PM
1976 27' Overlander
Missoula
, Montana
[QUOTE=Starstream;1697137]
You have to give them their own reference numbers (see some of the threads from Dumpster to get those pdf files) to get the shock mounts on - but they came already welded on. However, we ended up cutting them off and re-welding them on because they were slightly off. That is an advantage with some of the other suppliers, including Colin Hyde.
It was "drop off" easy enough - but putting them back on required about two of the eight holes to be recentered - and I used a "cutter" for that, but some use drills. By the recentered I mean some of the holes lined up, and at least two, maybe three were off enough that they had to be re-done. Why? I suppose because they are essentially making that set of axles a 'custom' job per your Airstream drawings - which are theirs, but I guess they don't do enough of them to keep them at hand. Thus, they all looked okay but were still slightly off. If I were doing it again, I'd order the shock hangers but have them loose, which they can do as well.
I suggest if you do it yourself, find someone with experience or at least the tools and have them help. I couldn't have done it by myself, without another set of knowledgeable hands. Plus, he had the welder and knew what to do!
WBCCI 1054
VAC
TAC
TCT
10-15-2015, 06:35 PM
Spring
good luck!
We found a place in Dallas that make semi-custom torsion axles but their 3,500lb axles only come in a 10" drum. In order to get the 12", would have to go up to a 5,000lb axle which is out of the comfort zone of the original 3,200lb Henschen.
Thanks again for the info.
10-15-2015, 06:42 PM
Spring
[QUOTE=OilnH2o;1697430]
Thank you for the info. I'll search for the pdf's.
Just to make sure I understand, when you say having the hangers loose. Do you mean having them welded on after you get the axles and put them on?
